Dash Lights
Recently some of the lights have been flashing on my dash. I believe they are the battery light, power steering, and a few others. The ABS light has not been flashing, but this morning all the lights that are normally flashing were SOLID as well as the ABS light.
Other than an alternator, is there anything else that could cause this?
Re: Dash Lights
Bad grounds come to mind or bad connections to the battery/alternator.
Re: Dash Lights
bad ignition switch can cause it. common on later subarus. try wiggling the key to see if they blink or turn off.
