Old 05-09-2011, 01:08 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
where's the best place to run wire?
i'm about to finish my subwoofer and i need to wire it to the battery. where is the best place to run 4awg wire from the battery to the trunk? forgive me if this was asked and solved elsewhere, but i couldn't find it.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 05-09-2011, 01:30 PM
Cam Cam is offline
Re: where's the best place to run wire?
I ran mine through an existing grommet in the firewall, down underneath the carpet along the driver side seat, along the side all the way back to the trunk.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 05-09-2011, 01:34 PM
B 4 You's Avatar
#lolsvx
did you have to drill any holes? could you post a picture (if you have one), and did you have to remove anything from the engine bay to access it?
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 05-09-2011, 01:38 PM
Cam Cam is offline
I was able to get it through the firewall fairly easily. I dont remember if i used a coat hanger or what...I definitely did not drill any holes. No pics of that, sorry. The grommet is behind the driver side valve cover (give or take) and will drop the wire right behind the ECU, if I remember correctly. These are the types of tasks that allow you to be creative and developed problem solving skills, so the best advice i can honestly give you is to figure it out. If you are stille having trouble later i can take a pic when i fet home, but see if you can make it work first
Cam
'92 Ls-L Dark Teal
Old 05-09-2011, 01:42 PM
B 4 You's Avatar
#lolsvx
okay thanks! i'm going to go attempt it, if i can't i'll just ask for that picture.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 05-09-2011, 03:34 PM
B 4 You's Avatar
#lolsvx
i can't find it.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
