Old 10-06-2009, 02:59 AM
Banned
Dual intakes with hydra.
So I'm curious, there are quite a few hoses that are connected to the stock intake. If I were to run two separate intakes what hoses would need to be connected to what?? also, would it be more beneficial to do this than to just do a single intake like the tomyx???
Old 10-06-2009, 07:53 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Dual intakes with hydra.
There'd be some benefit only if you felt the engine wasn't getting enough air with the current set up. Plumbed right, you could get some ram air effect at higher speeds.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-07-2009, 03:35 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
I could be wrong here since its been a while since I've owned an SVX with an complete engine bay, but I was thinking there's nothing connected to the accordian pipe except the MAF. If thats true then you just run one pipe to each throttle body, put a filter on the end and stick them where you want em. Again I havn't seen one in a while so Im not sure, but if nothings on the accordian pipe, which I can't think of anything that would be before the throttle bodies, then whats on the intake manifold shouldn't make a difference.. right?
Old 10-07-2009, 05:24 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Well, there are the seven hoses that attach to the bottom of the plastic bit right off the throttle bodies...
The question is, what would the benefit of dual intake lines be?
Old 10-07-2009, 06:49 AM
sicksubie's Avatar
Twice the surface area of the filters to pull air in through... I am still working on finishing my twin intake set up the only thing I had to do was put a small K&N air filter directly on my IAC. So there are zero hoses running to either intake pipe...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 10-07-2009, 10:25 AM
LetItSnow's Avatar
This can still be done with a larger single filter, which is much smaller than a whole additional intake line and second filter.
Just to know, how much additional filtering surface is necessary?
Old 10-07-2009, 11:42 AM
sicksubie's Avatar
the flow will be much smoother to each TB and I am running two of the biggest cone filters available from Green Filter.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-08-2009, 04:33 AM
Wow, theres 7? What do people with the Tomyx intake do about that?
Old 10-08-2009, 05:12 AM
yt yt is offline
They are all there.
Now with the lines you could simply get some vent filters, Just put the biggest on the line into one of the intake tubes, this is the idle air controller. The rest you could simply put some crank case breather filters on.
Old 10-08-2009, 10:51 AM
Banned
so what did you use to make the nipples on the new intake? Is it better to be closer to the tb or does it matter? So if I understand you correctly I just need the one nipple for the idle air on one of the two and the rest I put the mini filters on. For these mini filters, will it make a difference if they are name brand ones or can I get just any old ones that they sell at checker or whatever. It seems like the K&N are quite pricier.
Any one have a fact based or numbers based opinion on K&N vs green I already have one green filter, I'd like them to match so I could either get one more green or buy two K&N.
Old 10-08-2009, 12:09 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Sorry to be negative on this one... but unless twin F/I is being considered, I think the benefit of going dual intake vs Tomyx design is going to be trivial at best... your butt-meter might feel "zomg" but otherwise... you will have a rough time routing the driver's side intake with Fuel lines, Relays, Battery in the way... and then you got to worry about symmetry too...
my .02 rubles.
Old 10-08-2009, 01:17 PM
sicksubie's Avatar
Not routing it all the way to the fenderwell.. I am keeping it short and sweet, literally. Each of my intakes will have about 7" of intake piping total. If I were to decide to change it and route the intake into the fenderwell then it is very possible as I already tac'd one together that did that. I just want the intake length as short as possible....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-08-2009, 01:18 PM
sicksubie's Avatar
Johnny,
K&N flows great.................
As long as you dont mind dirt coming in.....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-08-2009, 11:33 PM
Banned
Johnny,
Lol. How about no
