Power Steering Question/Help
I need a power steering pressure switch. I found one at SSP Recycling, but they’re asking if I have engine speed sensor pump or electronic power steering pump. I have a 1992 SVX LS. Anybody have an idea?
Re: Power Steering Question/Help
My catalog lists a 1992 LS as having the engine speed sensing type and the LSL is electronically controlled.
Jackie Annapolis Subaru 149 Old Solomon's Island Rd Annapolis, MD 21401 443-837-1422 www.AnnapolisSubaru.com Jackie.Whetzler@AnnapolisSubaru.com |
SSP is an excellent company. I bought a whole rear sub-frame from them.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, |
Would you know where I could buy the correct P/S pressure switch? The engine speed sensing type? Much appreciated. Mark |
The part has been discontinued so you can no longer purchase it through a Subaru dealer. Even the pump is discontinued so that's not an option either. You can find a parts car or order a remanufactured unit from an aftermarket supplier. You might also try calling SVXFiles, he has a good selection of parts laying around. Best to call, he's hard to get ahold of electronically.
http://svxfiles.com/ Good luck!!! Part number for the switch as a reference - 34428PA000 You might also try contacting the companies that rebuild them like AC Delco, Lares, A1 Cardone, they don't list the switch separately on Rock Auto!
Jackie Annapolis Subaru 149 Old Solomon's Island Rd Annapolis, MD 21401 443-837-1422 www.AnnapolisSubaru.com Jackie.Whetzler@AnnapolisSubaru.com Last edited by SubaruPartsGirl; 08-30-2018 at 11:34 AM. |
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Thanks for the link, I'll be sure to save that site for later! Price isn't bad at all but I didn't fully check out to see what the shipping was.
Tags |
power steering pressure |
