Re: svx help
You need to drop out the transmission, separate the differential from the transmission and take apart the back of the transmission. Then replace the ring and pinion for the differential. A lot of work.
Or you can just swap in a transmission and rear differential from another subaru with a higher gear ratio that will give it better acceleration and seem to be much more reliable than the stock SVX transmission. As for things you need, You need access to a lift, other than that its just 10,12, and 14mm sockets and wrenches to do just about all the work. Search for transmission replacement and you should get threads on how to R&R the trans. Last edited by 1986nate; 03-13-2009 at 07:48 AM. |
Re: svx help
It's worth noting that the clutch packs in the higher gear ratio transmissions off the other model subaru's aren't actually as strong as SVX clutch packs. It's just a billion times easier to find one that isn't on it's last legs. I've rebuilt a couple 4.44's I sourced through svxfiles and while the clutch packs they came with didn't have the capacity that the svx clutch packs do they were in very good shape because they hadn't been pushing around a heavy, torquey SVX for 10-15 years.
Re: svx help
Re: svx help
i have rebuilt heads on civics and did 5 speeds. but i never had anything like this subaru b4. does it got to be a h6 tranny
Re: svx help
If you need any help, i'm fairly local to you. Best of luck!
Re: svx help
my dads 95 leg with a 2.2 blew the other day.
can i use that tranny |
Re: svx help
Oh and Mike(lan) did not know that about the other trans. I just said they seem more reliable because others have swapped them in and haven't seemed to have problems with them blowing up like the stock. I know the trans in my car was rebuilt around 65-75k and blew at 103k and I'm pretty sure people have gotten more than 30k out of a used auto from another suby. Just stating what I have noticed. I know you have the knowledge from actually seeing the internal parts |
