Stupidity strikes me again.
Today I messed up one of my lug bolts trying to screw on the wrong size lug. I could tell right away they didn't fit, but I saw the threads had paint on them and was thinking the tightness was just from that paint overspray. I decide to give it a few turns and see if it loosened, ..mistake!
Back to the computer to double check the size and sure enough I had the wrong size. Anyhow after getting the correct size lug nuts, the new one will not tighten all the way in on the that one bolt, so it looks like I need to have it replaced. Is safe to drive around for a week or so with 4 tight ones on the left front wheel until I can have it replaced? I am not having a good week.
Re: Stupidity strikes me again.
Go to a hardware store and get a die of the proper size (12x1.5??)) and clean up the threads.
This kit from Horrible Freight has the 12x1.5. I probably wouldn't trust it to thread a rod, but it should clean up the threads well enough. http://www.harborfreight.com/40-piec...set-39384.html I would drive as little as possible with 4 lugs.
Oh and just to make you even better, when I did a quick search to confirm the thread size I found it in a post that you made
http://www.subaru-svx.net/forum/show...1.5#post652812
For the record it is 12mm x 1.25.
I drove an SVX for 2 years with only 4 lugs on the right front wheel.
Should you do it? No. Will it probably be OK? Yes. Evidence:
Oh by the way, not that you have not seen this combo (Letitsnow's SVX for example) but here are the new wheels. I have to say they are flashy, and are very attention getting. ..and as a bonus they match my Outback AWD badge.
I when had the set of silver BBS on it I thought they were too light. I will likely keep these goldies for season or two then probably have them redone in a metallic gray.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 Last edited by Sean486; 07-09-2011 at 05:34 PM. |
Get a die. It doesn't look like the kit I posted has 12x1.25. But one of their cheap kits does, I own it and have used it on my lug threads. If you can't find one at HF, you can probably get the proper die at a hardware store or a good auto parts store like Napa.
That die is a good one to have, anytime one of my lugs seems to bind, I run that over it quick and it's good as new. If you're worried about the nut get the matching tap. Since you're just fixing threads it isn't important to have the proper handle, just use a socket/adjustable wrench/vise grips to spin it after you put a little oil on the threads.
Psh, next thing you know, he'll be putting a hole in his hood...
The lug studs are not too hard to change, I would see how bad the threads are maybe run over it with the die as mentioned. I would certainly check out that lug nut as if the threads are messed up in there it will screw up the new, or refinished lug stud.
I changed one stud on my RF and 2 on my RR. Tire shop messed up on a friday afternoon and I wanted it done sat and no one could so I did it myself, made them replace the lug nuts and since they couldnt be got any more got an entire set still they got off lightly. I did not need to remove the hub just worked out the studs and angled them and turned the hub till the larger hole lined up. patience was key. |
Yay!! it's fixed. I was able to have a friend help me and we got it replaced. The lug stud and lug nut were completely beyond repair. Ordered a punch and die anyway, they were cheap and it seemed like it will be useful.
I could use a few more stock lugs though, I destroyed a few during the repair. Fun173 thanks! I was pretty uncertain about whether I would like the color on a silver or not. But it turns out I like them a lot (and they look great on your red one too).
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 Last edited by Sean486; 07-10-2011 at 12:19 PM. |
Hey Sean
I have extra lug nuts, they are yours if you want them. Let me know when you will be in Bethlehem again.
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD 92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD 92 Teal SVX LSL lowered with Konig. SOLD 92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone 94 Red SVX L FWDwith LSL Leather Interior. SOLD 92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD 95 Polo Green........With Trany Problem. GONE Almost complete Rear Wheel Bearings Job with Pictures in my locker My Locker http://www.subaru-svx.net/photos/user.php?pearlm30 |
That would be great thanks!
