Polish Poly Suspension BUSHINGS - Red/Yellow
I've read al the previous thread on these when first interest was developing.. HOWEVER, I see almost no comments on how either the Red or Yellow polys were appreciated by the users here.
I'm considering buying the entire 276051A package (20 bushings + new front sway bushing brackets) for the Network price of $300 incl S/H. All I've heard .. is that wishbone Reds may be too soft.. and that Yellows in general may be too stiff.. ?? Please lemme know.. so I can accept the discounted offer .. or just get wishbone bushings (yellow I guess).. . Someone here has suggested that my failing wishbone OEM bushings could be the source of my (metallic) creaking noise .. when accelerating sharply (rt or left) from stopped! I already have old red poly sway bushings (new Yellows??).. . Thanks, Jim P.S. Are lateral link, trailing arm bushings really necessary.. ?? Do they go bad? How do we know?? P.P.S. Also, a friend says polys squeak.. will that be a problem for all these polys installed?? (I have some squeak with sway bushings.. Gotta spray occasionally.)
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 06-01-2012 at 10:46 AM. |
Re: Polish Poly Suspension BUSHINGS - Red/Yellow
Hi Jim,
I replaced all* of my bushings with the yellow poly bushings. In my driving, I have found that while the yellows are quite stiff, I feel they give a great feel of the road, and I still get a very comfortable ride from the car. My Poly Bushings do squeak quite a bit, but I believe that the shop who pressed them in for me either didn't grease them, or didn't grease them enough, however, depending on how you drive, they might not be to noticeable. When my stereo is on, I don't hear them at all, and when the windows are open, I only hear them when I am not going "fast" ("fast" being >35mph). They also seem to be getting quieter as they wear in, or I'm so used to the noise that I don't notice it anymore All that is of course, dependent on how you drive, and how you want your car to perform. Roads and Suspension travel may make substantial difference I had bad bushings in the rear (my car had a rough life before I got it) and a bent parallel link, so I replaced the bushings since I had the car apart, I likely didn't *need* to, but hey, I had the kit. ~TEck *I didn't replace the bushings in the rear hubs, as I didn't have anything to take the hubs out with. I know that OT recently did a set of these bushings as well, and he had a trick to doing the hubs while they were on the car, but I can't remember what it was of the top of my head! |
Thanks for your input!
I think the technique you're referring to .. for rear bearings (on the car) .. is the HubTamer. I have one.. about $250 when I got it on eBay.. ? Allows you to press old bearing out/new bearing in.. while hub remains on car! Still not easy, but I guess easier? or "better" for some reason? I have never taken hub off? Well.. Do you WD40.. PB Blaster.. or Silicone spray your polys? Maybe wud be "easy" help? We can't get OEM wishbone bushings separate from wishbone..can we? It doesn't show part # on SubaruParts.com! So, we cud press in a new set of OEM bushings.. ? I'm sure not gonna buy the whole wishbone w/ bushings! Thanks, Jim
What's this about squeaking? I want a full replacement but a squeaking car?
I got my girl, I got my glass, I got my car and I'm ready to f... |
Poly bushings make noise if they are not lubricated. White Lithium or Silglyde is great for them and readily available.
The Grease comes with the bushes - better to put too much on & wide off afterwards, if you run out then head over to your local supplier for some more.
I bought the full yellow setup with no issues, last year - firms up the ride, also just bought the 15 minute mod in yellow, should be here this week (they arrived tonight & look great!!). Still to fit the Koni inserts that have been sitting around for past 8 years!! (the ride still felt firm before fitting the yellow poly's) Last edited by SURTEESS; 06-06-2012 at 12:05 PM. |
