Head light level Adjustment?
Seems like my lo-beams are aiming bit lower and I've tried to adjust with those screws right next to the lo-beam housing, but didn't change.... Am I supposed to turn way more?? Or was I turning wrong screws?? I thought those were the level adjustments. If anyone could explain how to adjust the level, that'd be great!
Thanks.
-Ryu Links: 2004 Honda S2000 (2008~) 1992 Subaru SVX LSL Liquid Silver (2007~2008) 1996 SVX LSi Bordeaux Pearl (2006~) 2002 Lexus IS300 Sportcross (2005~) 1992 Subaru SVX LSL Pearl White (2001~2005) 1994 Mercury Sable GS (1999~2001) 1/43 Scale SVX Models [SIGPIC][/SIGPIC] |
The little levels on my headlights are broken so I just do it by the "drive the car up against a garage and use the door to adjust them"
Driveway isn't flat, but you can stand in front of the car and see how high up your legs the light shines
And then level them against the garage door. |
You guys are way too scientific about this. Just make sure it is dark, then put on your favorite baseball cap (or fishing cap if you live in the South). Turn on your car's bright lights and walk fifteen long paces directly in front of the car (it is important that the engine isn't running). Turn and face the car covering your eyes with your forearm. Squat. Tip your cap's brim forward (put it on right, not backward, idiot) until the light doesn't make you squint. If you can still see part of the car your lights are OK. If all you can see is the ground you need to raise them a bit. Give it a try.
Preston |
Make sure your car is level, use a level on the door sill. Check that the bubble on the settings of your head lights correspond with the level on the sill. If you want higher beams (bubble should be more towards the front of the car), If you want lower beams (bubble should be more towards the back of the car). Try all the screws one at a time to see if it affects the bubble. Then set as desired.
how do you see the light if your forearm is covering your eyes...then tipping the cap lower wouldn't mean anything....hmmm I guess I should try it....
Um..why turn the engine off?.... |
