After MAF installed
I just put a used supposedly working maf in my car after getting code #23 and the car running rough and stalling out. Well it started up fine but then promply stalled out again after a few seconds or so. A friend suggested unplugging the negative side of the battery for a minute and then trying it. This didn't work either. Is they're anything else I need to do or can try? I am also getting both oxygen sensor codes as well but have never had them stall the car out. One is fairly new as well. Any help appreciated.
Mike
95 Pearl Blue L |
try resetting the codes? I replaced my MAF and O2 sensors, it fixed the rough running but the codes stuck around
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
Thanks for the reply. As soon as I start the engine the check engine light stays on so I don't think it will erase. I'm going to hook it up and try it though.
Mike
95 Pearl Blue L |
The ECU needs to be unplugged for at least 30-45 minutes to completely erase everything. After that, reconnect the terminal (or ECU fuse). Then you need to start the car and wait 10 minutes or until it's warm (Don't rev it or take it out of park). Then shut the car off. Then you can drive it.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi Last edited by Manarius; 09-20-2007 at 03:24 PM. |
Manarius, what exactly do I disconnect. The battery or a fuse. Sorry I am so uneducated on this. Thanks greatly for the help. I can't even get to work now. I'm going to disconnect the battery now.
Mike
95 Pearl Blue L |
take the negative battery terminal off and leave it off it uses a 10 mm nut while the terminal is off turn the ignition on to make sure that the ecu is drained of all power even stored power hope this helps ps make sure ignition is off when you reconnect the terminal
