#1201
Re: SVX Engine cooling "Again & Again"
Try to follow me on this one. It may be a cheaper alternative to making a custom Y-pipe for a coolant crossover.
Take your OEM coolant pipe, and tap a hole on either side toward the front of the block. Insert brass threaded fittings, and use a flex hose between the two fittings. The point would be to bypass the portion on the rear side of the block that connects the two sides. Coolant will still flow throughout the entire assembly, and equalize pressure as well. My thought here is this would help coolant travel from the driver side head to the radiator. Rebuttals?
#1202
Cam the difference in the left and right head coolant flow is nine tenth's of sweet f all. So if that the purpose of what you are trying to do the gain won't improve cooling. You still need to address the vacum issue on the pump or you won't have coolant to transfer.
Tony
#1203
You mentioned you think your issue is resolved. When will you have a chance to track the car again to verify?
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#1204
#1205
Chuck Matt has raced his twice and it runs cool. In his case the only change he made was the bottom pipe out of the radiator and the thermo cover. I understand he will race again in November. In my case it will be next year due to the silly season at work,
Cam I persoanly would not change the top pipe as I haven't seen any reason for it on my test bench, but that just my preferance. Tony
#1206
Putting the theory to test here stateside myself(50mm inlet, inline upper thermo)
Some pics of the setup here as I'm throwing the car back together now. Been off the road for over a month now and I'm ancy to drive it again. |
#1207
Interesting approach! I'll be watching your tests.
#1208
Looking good Adam I really like the way you got the feed system to the pump.
Tony
#1209
that's the drop-in fitment sti radiator I had in there, just crudely modified to suit this test for now. I have a full griffin core that, if this works like it should, I'll be making my own core tanks without all the crap on them that had to be blocked off due to the new routing.
Should be running and up on the dyno ~ sat or so. |
#1210
Adam depending on the core size at full revs you may get some coolant out the overflow due to top tank pressure. When you go to final design its best with side tanks.
#1211
Never had an issue with this rad before. My overflow is not at the radiator. That cap there is just to let air out of the system while filling to speed up the process. Main pressure cap is up off the surge tank. |
#1212
This one's for you Team Ill.(lolz)
Update for you folks. Car has been running just fine, and by fine I mean no more than 186F on the dyno running 3rd gear at 5500rpm for over two minutes flat with nothing more than dyno blower fan airflow over the rad. Winnar winnar chikan dinnar! |
#1213
definitely a lot of good knowledge here, I don't know much about fluid dynamics but have learned a smidge from this thread. |
#1214
As regards increase power or forced injection the answer is Yes. I will quilify that by saying your radiator needs to be big enough and air flow needs to be high enough to transfer the heat. The abilty of the block to transfer heat to the coolant is a "fixed surface area" so if you need to get more heat out of the engine the coolant needs to return from the radiator as cool as possiable. With out try to baffle you with Bull____T the rule is, "Greater the difference between the coolant and the block for a given flow the greater the transfer of heat from the block in a give time" Hope that helps. Tony
#1215
I have a 170F thermo in it. Normal temp while driving fully warmed is 168-175 pending vehicles speed. On the dyno it creeped to 186F after a minute of constant running, then held steady until I took my foot off the throttle some odd 60-80 seconds later
If people want I can fab a few of these 50mm pump inlets for those looking to do this. Will be a straight lip, you'll just have to modify your radiator to suit and use an appropriate 2" ID hose. |
