#301
That cleans me out of both valves and valve springs. I got both manufacturers to make and hold extras for me so I'm going to call and order some more now. Anybody who's looking to get these in the immediate future please let me know before I put in my order.
#302
Build Progress
On another note and to update my build, I dropped off my heads and block for cleaning, valve removal, and testing. I'm using a local shop called bumper to bumper. I was recommended to them from a Nasioc member. I was dealing with Chris Fenhoff. He seemed to really know his stuff. He thinks that everything should clean up fine. I still have not had any response from ARP regarding head bolts, or from Mr. Gasket regarding copper gaskets. I'm going to keep bugging ARP. Mike, if you are still interested in supplying these bolts after we work out the sizing, I'll mention that to ARP. Since our aftermarket is so small it might be best if these kits were offered on your site. My critical path is getting ARP to either pass or commit on main bolts. I raised the issue that Mike brought up regarding the need for sealing these bolts/studs. Once this is decided, I can semi close the deck, do the bores and mill the block (.001) to even everything up. Then I can get cracking on the bottom end assembly. As far as the head gaskets go, I'm going to go with the cometic gaskets. I just e-mailed an e-bay company offering these and will purchase them soon, if they are on the level. I also need to purchase the engine seal overhaul kit. Anyone need some head gaskets?
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#303
there is nothing out of the ordinary about installing the valves or springs. Everything is drop in.
#304
Shipping was about $45.
Ok everybody, we hit our first and hopefully last snag.
I need everyone to send their intake camshafts back to me. It looks like about half of the cam journals on the intake cams are some ten-thousandths larger than the base circle of the lobes. This will make the lifters ride the cam journals instead of the cam lobes when the valves are fully closed and we don't want that. We just went through the oil clearances on the journals and there is enough room to grind the journals to get our clearance. Send them to the Miami address: Michael Emery 8240 SW 184 Lane Miami, FL 33157 |
#306
Snag
#307
The problem is out in the tenths of thousands of an inch. I'd rather just get them all back and have them ground so we have some clearance.
edit: everyone please ship asap so we can get them back to the cam grinder and back asap for those who are in the assembly process already. Quote:
#308
Oil clearance
#309
Oil clearances on cam journals aren't nearly as critical as on crank journals but it never hurts to check them. We'll end up all the way on the loose side of the range but that should actually be better for us--the increased oiling of the lifters will make the cam lobes last longer. The exhaust cams get oiled better than the intake cams.
Cams
#311
Cams
#312
chucky two times,
no I haven't no I haven't haven't really thought about it haven't really thought about it |
#313
Base Circle
I just spoke with the guy who is machining my block, and discussed the issue related to the base circle and the journal diameter. He did not think that this is going to be an issue. He said that the base circle rarely comes in contact with the bucket if at all. I think your idea to regrind another cam is safer, but do you really think that under these circumstances a coating or plating will be that affected by bucket friction? Let me know what you think.
I've just had some personal issues come up that will require me to finish this build quicker so I'm hoping the cams will be ready soon. Thanks Chuck D.
#314
Chuck.. the cams NEED to be redone. Otherwise the lifter will ride and wear on the cams. This wearing doen ridges on the lifter and thuse will deform the cam lobes themselves. I just sent out two more sets of intake cams to Mike's machine shop. Now NONE of the good motors I have still have any cams in them at all. SO im up the creek on getting my EG33 wagon project off the ground. One set is high priority to someone else who has gone through a fair share of cams... The other is going to me. I need to have my build done in time and broken in for the Subaru Challenge at the end of september... I am still questioning this being feasable but we will see. I am not sure of what Mike has received yet along the lines of core cams but you can always go searching for them yourself to speed the process.
Tom |
#315
Solution
I understand the issue. I'm just telling you what my machine shop guy's opinion was. It would be nice if we had a solution that does not require buying a new set of cams and regrinding them. Coatings or plating might work. I would be willing to guinnie pig for something like this.
