Old 01-19-2014, 02:45 PM
Taillight Issues
Things have started to pop up here and there after the hibernation. Just today I discovered that I had no side rear lights and when braking, the secondary bulb lights do not turn on.
Arrived home (nighttime), turned my lights off, ignition off, and the taillights stayed on
Turned the car on, lights on, lights off, nothing still. Did that like 3-4 times, until the taillights are off along with the car. Weird!
Note that I was checking the lights after I go out of the car, and not doing the stupid mistake of foot on brake pedal or smthg...
What do you guys think?
Old 01-19-2014, 04:22 PM
Re: Taillight Issues
Could you accidentally pressed the parking light switch on the lower dash panel. The switch with the "P" on it.
If depressed, it turns on the parking lights, front and rear side marker lights, tail lights and license plate, regardless of the position of the ignition switch or whether the key is in the ignition or not.
Old 01-19-2014, 10:15 PM
I know about the P switch John, no that's not it. Part of the taillights (sides in the fenders) are not working. When I push the brake pedal, the secondary lights in the bulbs do not light up either. Really strange...
Old 01-20-2014, 05:00 AM
Have you tested with a meter?
Old 01-20-2014, 05:11 AM
michael's Avatar
michael michael is offline
What Potholes ???
Mine did the same thing a few years ago. I never found the exact cause, but I simply reseated all of the bulbs and it never came back.
Wanted: Steering Wheel
Old 01-20-2014, 08:20 AM
wdb wdb is offline
dances with roads
Weird electrical gremlins indeed. I'd look for bad grounds and/or bulb oddities such as crossed filaments. They can do strange things to the path the electrons will take.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 01-20-2014, 10:42 AM
Tomorrow is SVX day. I will tackle multiple things and will update you all with the progress.
I have a gut feeling that the lights switch of the steering column is malfunctioning.
Old 01-20-2014, 08:06 PM
92 SVX 92 SVX is offline
Sorry I could not be more help today, I was out helping a kid with his honda.
Old 01-21-2014, 12:19 AM
Its ok Gene.
I just had a very sweet morning. Got into my car, turned the ignition and tick tick tick.... battery is dead. Either i have a bad alternator or a serious electrical drain. Happy me...
Old 01-21-2014, 04:21 AM
Its ok Gene.
Low battery may be causing those electrical gremlins?
Old 01-22-2014, 10:38 AM
Solution turned out to be stupid. The brake light switch above the pedal needed adjustment. The screws were a bit loose (dunno why). I ended up removing the switch, clean it with a spray electronic contact cleaner and adjusting it to the correct position. Problem fixed.
Old 01-22-2014, 03:07 PM
Blacky Blacky is online now
Excellent, free and easy, the best kind of repair.
