sunroof repair
Any body ever taken their sunroof/moonroof apart?
I found a used track, but have no idea where to begin in removing the old one. I also wanted to remove the roof portion as well, to see if I could better view the problem. Any hints or tips of wisdom? Ian |
I've gone so far as to remove the roof panel, but never messed with the track. If you open the roof to the vent position, you should be able to remove the inner panel, I believe it slides aft. Then you should see the bolts that hold the roof panel to the brackets on either side.
KuoH |
