Old 11-25-2008, 07:50 PM
oab_au oab_au is offline
Re: The infamous IRIS Valve
Originally Posted by b3lha View Post
I've been trying to find the part of the ECU that controls it to experiment whether there is any benefit to opening/closing it at a different rpm than stock. But I haven't managed to find it yet.
As I understand it, with the iris closed, you get more power at low rpm. With it open, you get more power at high rpm. I can't imagine it would be benefical to remove it unless you were doing other mods to the intake system.
I think it will just be driven by rpm. Closing at 2200, opening again at 4000?
It won't work at other rpms as it has to work with the Inertia speed of the air, which is a fixed speed due to the mass of the air.
Thats why it is opened at 4000 as the speed that inertia flow can increase the flow is too slow, from 4000 up. It opens to allow the inlet to move to a Resonate system as it works best as the rpm goes up from 4000.
One Arm Bloke.
Tell it like it is!
Old 11-25-2008, 10:45 PM
Banned
I love this site! hahaha gosh, I got more than the answer I wanted! Sweet! I learn a new thing everyday!
Old 11-29-2008, 12:21 PM
ZMan's Avatar
ZMan ZMan is offline
More info for you.
Old 11-29-2008, 01:35 PM
kwren's Avatar
kwren kwren is offline
Originally Posted by ZMan View Post
More info for you.
Very GOOD!
Old 11-29-2008, 03:37 PM
More info for you.
Good Pict's, but he has got the info from the Road & Track description, that got it wrong.
The Inertia system is when the valve is closed,at low speed.
The resonate system is when the valve is open, at higher speed.
This is my description of the Inertia system operation.
http://www.subaru-svx.net/forum/showthread.php?t=1141
This is the Resonate system.
http://www.subaru-svx.net/forum/showthread.php?t=29170
One Arm Bloke.
Tell it like it is!
Old 12-08-2008, 07:27 AM
degeso degeso is offline
Send a message via MSN to degeso
people remove it because they are lazy or cheap its there for a reason usally what happens is that it gets so dry it snaps in half. mine did that its a 20 dollar part without it the engine is rough. i have 185000 miles on my ***** and cant even feel if the engine is running at a stop light. its worth fixing little things like that especlly that easy to fix
Old 12-08-2008, 08:33 AM
want-a-fast-svx want-a-fast-svx is offline
Send a message via AIM to want-a-fast-svx
I believe you are referring the the little check valve behind the p/s pump? Where as the others are talking about the butterfly in the center of the manifold. I could be wrong but thats what i am getting out of it.
Old 12-08-2008, 11:12 AM
Schralper's Avatar
Schralper Schralper is offline
Originally Posted by dennyo View Post
if it's not operating properly what would be the symptoms say if it didn't open?
You can get ruff starting issues when it's cold.
ask me how i know
though i think it just needs cleanin/lube.
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
