when did Subaru make changes to SVX
What improvements did Subaru make to the SVX after 1992? I remember reading on the forum that some initial flaws (something to do with transmission?) were corrected in later years, was wondering if these came after my 94?
they added an external filter which did help lower temps a little bit and increased the system capacity which therfor means the fluid breaks down at a slower rate. The same modification was available for the earlier models based on a recall i believe. It is generally a first step in owning an SVX to make sure there is an external filter, change it with the fluid regularly and add an external cooler while you're at it if the previous owner has not. They also offered a front wheel drive version in 94.
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? Last edited by Speedklix; 04-12-2008 at 11:43 AM. |
thanks, I thought maybe the modification was added pre-94, I have no idea if I have external filter, will have to find out . you can tell I know next to nothing about cars... Slowly learning. With my SVX I wish I knew a lot more.
My '96 doesn't have the external filter. It does however have a cooler.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
They also removed the filtration material from the transmission cooler in the radiator. It would get clogged and prevent the transmission from cooling properly.
Simply switching from conventional tranny fluid to synthetic fluid is a large step in the right direction.
I have yet to put a cooler on mine, but one of the first things I did when I got the car was flush the transmission and replace the fluid with Amsoil synthetic automatic transmission fluid (ATF). I guess it's hard to tell damage form the outside, but so far so good. MY old fluid didn't look as bad as I thought it would, but getting the old gunk out and putting in fresh oil is always a good thing. That said, I DO have a cooler in the garage waiting to be installed. I didn't really see the point of installing a cooler in the middle of the winter though.
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
