measured the roll center of front suspension
Over the last year or so, I've been doing some reading on suspension geometry and wanting to do some measurements of the roll center and the center of gravity of the SVX front and rear suspension. Been too lazy up to this point, but the Aug, 2005 issue of SCC has a nice article on measuring suspension geometry, so I finally climbed under the car to measure the front suspension pivot points. Turns out the SVX front suspension has a very typical MacPherson strut geometry. The roll center of the front suspension at factory height is about 2.75" off the ground. That's kind of meaningless all by itself. What's more important though is that now that I have the suspension geometry, I can determine what effect lowering the car has on the suspension geometry. Turns out that lowering the car 0.5" has the effect of lowering the RC by about 1.25". Probably sounds great, but actually, this is bad. Because the RC drops more than the CG, the roll couple increases, and a larger roll couple causes cornering forces to make the car lean more.
For you folks who want to get the most handling out of your lowered SVX, the way to stop the increase in roll couple when the car is lowered is to move the A-arm ball joint further from the spindle. I think this might actually be easy with the SVX because the ball joint is pinch-clamped to the spindle. If the ball joint can be lowered 0.5" in the spindle, then the CG can be lowered without adversely affecting the RC (for a car lowered 0.5"). I'm thinking that some kind of spacer might be needed too, but otherwise, I think its possible. In a day or so, I'll post some drawings showing my suspension measurements.
and some drawings as to how we could fabricate up such a spacer?
I'm not experiencing much lean at all with the sway bars and Konis that I'm using in conjunction with your springs....but then again, I do understand the engineering behind what you're saying -Bill (still trying to find the time to adjust his OEM rear bar in order to reduce the 4" inner rear tire lift seen in recent autoX photos....) p.s. did you do your own measurements to determine the scrub radius?
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 06-24-2005 at 10:52 AM. |
Mychailo,
I'll be getting your sport springs this upcoming Xmas (due to unforseen wheel bearing and 4EAT replacement this Spring/Summer). As I live in the country and drive on several imperfect roads, I'll probably go with the custom springs you've made for a few customers that retains the stock ride height, but increases stiffness. I'll still be interested in seeing your findings... -Chike
Accurate explanation or no?
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
Last night, I looked at the ball joints that I took off my car last summer, and it should be possible to drop the ball joints about 0.25" without much difficulty. Any more than that, would require an adapter that would probably result in dropping the ball joint by an entire inch. For the 0.25" drop, all that's needed is to cut a radius into the shaft of the balljoint so that the pinchbolt can get past the ball joint. I'll post pics on that soon. Bill, yes I was able estimate the scrub radius from the measurements. My estimate is that with stock wheels, the scrub radius is about -20 mm which is pretty close to the value of -27 mm that UberRoo got. So it seems that the scrub radius is indeed a bit negative. Kinda interesting.
But if you alter the location of the pinch bolt won't that make the ball joint stud susceptible to breakage? The slot relies upon the clamping pressure to make it secure and dropping the slot below the pinch bolt could prove hazardous. Another consideration is the unsupported length of the stud is increased. Seems to be akin to taking a few whacks of an axe to a tree trunk...
