Transmission Slipping Please help
I own a 1996 with about 200,000 miles. I noticed it would like to drag the shifts from 2nd to 3rd and 3rd to fourth but never really saw it as a problem. As of now the car barley will shift into fourth and 3rd is not all there. It tends to drag under heavy loads. First and second are just fine. Im thinking it has something to do with the Line pressure. I have been doing some research on it and found that Solenoid A valve goes bad. Now if that is the problem I have no idea where to find this or how to replace it. I thought I once read something about resisting the pressure but I'm totally lost with that. Also I thought I read something about cutting a line which would give me hard shifts. Thats fine I just want to get a little more life out of her. I'm totally lost as to what to do and any info would help!
Thanks |
Re: Transmission Slipping Please help
well i bought it with about 175,000 and as i was told it was rebuilt at about 100,000. I have kept it up pretty well. I flushed it when i first got it and have always kept tabs on the fluid level. Im hoping its something with line pressure.
It would appear that you have been cautious since you noticed the problem and therefore it is reasonable to hope that nothing has been seriously worn due to slippage. You are correct in suspecting low line pressure. This can be easily tested by someone with the right equipment and the test will cost very little. If low line pressure is detected, this can be due to a faulty “A” solenoid valve, which can be checked and if necessary replaced, without removing the transmission, and at a reasonable cost. Keep fingers crossed.
Thank you all. And yes, Im crossing my fingers! =) |
The resister is a small elongated metal enclosure, mounted on the panel behind the battery. It has a plug/socket connection. The resistor circuit is there to protect the "A" relay against sudden closing shock. I can provide detailed information if required. If you disconnect the resistor, do so only to get you by meantime. If you find that it is disconnected or is open circuit (bad), you have found the reason for a faulty "A" solenoid. Keeping fingers crossed for you.
