Water in trunk, after sealing taillights...
The trunk seal seems good, and I already pulled the tail lights out and sealed them... Now I'm confuzzeled. Any other known leaky areas in our trunks? Rear wiper maybe?
92 Teal 181K 4:11 trans Lightweight crank pulley Redline Shockproof Trans Cooler Viper 550 HF Alarm/Remote Start 18" Enkei Evo5's |
Might want to check the rear sunroof drain hoses to make sure they are not loose or broken. They run down inside the side panels. Sometime back a forum member mentioned a leak around the antenna.
Gene
When mine weren't plugged in, they drained into a little "reservoir" type thing off to the left side of the trunk. It's hard to get to if you still have to trunk panels in, as you have to reach down pretty far.
bLAh
Thanks guys, I'll take a look next time I'm home from work before dark
