#76
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#77
phil
#78
phil
#79
As I mentioned in a previous post, ethanol from agricultural sources which compete with foodstuffs won't get the job done. If you do the numbers, you will find meeting our gasoline consumption with ethanol produced by corn or sugar beets would use up the entire production of these crops. Such is the magnitude of our gasoline thirst.
The bright spot on the horizon is cellulosic ethanol, which requires a 2 step process. The first is to convert cellulose into sugar or starch, which is exactly the process that goes in the gut of a cow to allow it to live off grass. The resulting sugar or starch can then go through a conventinoal fermentation process to convert it to ethanol. The important thing about cellulose as a raw material is that we have so much cellulose waste. All agricultural waste, corn shucks and stalks, wheat chaff, dead leaves, sawdust, etc, all are mostly cellulose. Converting this stuff into ethanol and then burning the ethanol as fuel will not add to the carbon dioxide content of the air, because this stuff will oxidize anyway as it rots. There will be an initial burden because, undoubtedly, converting this stuff to ethanol will reduce the mass of it sitting around and rotting, but once you are up to steady state production, there would be no net gain of CO2 to the atmosphere.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#80
So are you going to drain the old gas or run the tank empty before switching to E85?
Would it be possible to get the ECU to automatically adjust for different ethanol levels? eg. 1/4 normal gasolene + 3/4 E85
#81
The span between rbt and lbt with ethanol/e85 is much larger than it is with gasoline. You can run way way way rich without loosing power. This means if there are a couple or few galons of gas left in the tank thanks to our fuel guage and tank design which likes to leave us with a few gallons in the tank it will still run just fine.
A small amount of ethanol works as a great additive to gasoline for increasing the octane level. When you are switching back to gasoline you will want to get the tank as empty as possible before you fill with gasoline but you still shouldn't have to drain the tank. Fill up with E85, start the car while still on the ethanol code, a few seconds later when the fuel lines are running gas and the car starts going rich rich rich throw the switch to go to the gasoline code. With a couple gallons of E85 mixed in the tank with gasoline your lambda will be slightly leaner than if it was straight gasoline but with the increased octane it should still run just fine. You should have no problems going back and forth between E85 and straight gasoline. Just run the tank pretty close to empty before you switch. Quote:
#82
Can it be switched on the fly or do you have to shut everything off first?
#83
It's the same switching mechanism as always and can be switched on the fly. When going from E85 to gasoline you will want to switch on the fly. When going from gasoline to E85 you'll want to switch before you start or imediately after on the fly.
#84
Bitter, no, I could care less as I rank drag racing right up there beside the WWE as sports go and besides, we only have you to blame if we can't break into the top ten. I'm simply waiting for an explination as what they are talking about defies science. No one here seems to be capable of showing that e-85 is capable of higher power then regular gas is. Then again, that was to be expected since everything I've read on it since someone first brought up the idea contradicts what L............... is saying.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
#85
So Ben, you are honestly suggesting that if I run E85 in my car with the diff crank pulley say making about 17lbs of boost that my performance will get worse than I am on Jersey 90/10 fuel at 12lbs??? Are you ****ing serious?? Yes I will burn more fuel but at the same time I will not be burning as much money. Jusitify that as a loss and a waste of time
Tom |
#86
Please refrain from commenting until i post on my results.
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. Last edited by Phast SVX; 09-06-2006 at 02:48 PM. |
#87
If you read my posts Tom you saw that I asked for an explination as the racing communty as a whole has shyed away for the reasons I brought up. Oh and some that I didn't such as heavier weight to go the same distance as you need more fuel, less life expectancy for the engine and components as the engine corrodes into dust. As for your comparison you just changed the senario though. Making 12 lbs of boost you won't have any gain from running e-85 than you would making 12lbs of boost with gas. You need to compare apples to apples young t not apples to steaks. Better fuel, not in the least, better tailpipe emissions sure. Remember the racers that have gone to e-85 have done so for some very good reasons: ALL cars in the series need to as it is sanctioned and marketing.
#88
Seems like E85 will only benefit forced induction vehicles by allowing higher boost levels.
#89
phil
#90
