Drive shaft un balenced?
I converted my car to a 5spd, and used the small car basic install kit, so iam using the drive shaft extension. When ever i go above 70 MPh there is a pretty bad drive train vibration, i think my engine taps the hood . what do you think it is, is it a unbalenced drive shaft, becasue of that stupid spacer, or is it something else. Isent the 2 gen legacy 5spd drive shaft spose to be the righht lenght? Thanks
If the vibration is coming from the front end of the car (e.g., engine tapping hood), its probably not the driveshaft. From experience with my SVX, an unbalanced driveshaft will be felt from about the middle of the car and further back. Maybe a bad CV joint or unbalanced flywheel? Seems to me that Earl (ensteele) had a similar problem with his SmallCar 5MT swap, and it turned out that the spider gears in the front diff failed, and then the chips floated around in the tranny and totally killed it.
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 07-30-2004 at 06:06 PM. |
I have a bad driveline vibration at over 70mph and I'm using their driveshaft spacer also. I would like to eventually have a custom driveshaft made.
cant you use a 2 gen legacy drive shaft?
It could also come from loose tranny to engine bolts.
