My sunroof is screwed!!
My sunroof will open on one side and not the other. What do I have to do to fix it?
Re: My sunroof is screwed!!
Keith |
Sounds like you might have a broken cable on one side... You might be able to drop the headliner enough to see what is going on under there with a flashlight, but I am not sure, being a two door car you might have to remove the back window to get the headliner out if you do have to change out the sunroof mechanism, although you might be able to just take the seats out and drop the headiner down and work though the sunroof hole. I've attached some PDF files from the factory service manual for the sunroof, hopefully they will help.
(Mods might want to sticky this, or put them in the service section)
1992 SVX LS-L #1222 Pearl White 1987 GL Turbo wagon, 5 lug conversion, D/R 5 speed (Rice killer) 1992 Dodge Ram 4x4 diesel (car hauler) 1968 Dodge Polara convertible (Camaro killer) 1990 Toyota Corolla FWD auto (330,000 mile grocery getter) 1986 VW Jetta Last edited by Hondasucks; 08-10-2008 at 01:19 AM. |
thanks, smartass!
Sounds like you might have a broken cable on one side... You might be able to drop the headliner enough to see what is going on under there with a flashlight, but I am not sure, being a two door car you might have to remove the back window to get the headliner out if you do have to change out the sunroof mechanism, although you might be able to just take the seats out and drop the headiner down and work though the sunroof hole. I've attached some PDF files from the factory service manual for the sunroof, hopefully they will help. Thats kinda what I thought, I just have to take the headliner down thank you! |
There you go!
I knew you could work it out! Let us know so if mine ever does that I won't have to "Take a look and see why" Hope it works out well for you! Keith |
