Remote mounted turbos...
My buddy told me about these a month or so...
Remote turbo company The website was interesting, a good bit of it was mistated or taken out of context, their comparison graph was not specific to the remote mounted application and the glowing turbo was likley running on an engine stand at WOT for a good while, never the less, in the tight SVX engine compartment I found this interesting.
.Karl. Southwest members, click here to check in!CA,NV,AZ,UT,NM,OR,CO Wanted...your busted SVX! Watch out Earl, I'm comin to getchya Return of the Pissed Platypus! X2 My dream (other than a pearlie) 1.8 SVXi and a laguna blue spoiler...somewhere I decided to quit drinking, but I didn't like it so I quit not drinking. |
If you waste your money on that piece of crap I'm going to smack you.
Brian |
These are old news. No offense, running the intercooler piping would be a PITA not to mention oil/coolant feeds as well. I also think an exhayst system loses too much velocity going that far that the turbo would not be able to function properly
Tom |
I figured if I did it then I'd build my own, that company smells of rat
WTLW .....
There have been many threads on this....
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
It's not a good thing if your turbos and hot parts aren't glowing red.
Remote mounted turbos are very real and work well.
turbos work due to exhaust gas flow and heat. Without the heat, they are functioning on flow alone. when this far back on the exhaust system, the flow is significantly decreased thus not allowing for a larger turbo to work. A turbo too small will also merely be a restriction.
Tom |
with that said, it will be hard to get the turbo to flow higher cfms and with such a larger piping system, keeping boost up is gonna be a killer. MUCH better off with a conventional front mounted system.
Tom |
Absolutely I agree with the above. I would assume throttle response would be a major downfall of this kind of setup with the length of plenum you have to run. I would also assume this setup would be for the bigger displacement motors (ie 3.0 liters and up) as exhaust flow is key. My .02 cents.
1992 Subaru SVX 2000 Daewoo Lanos 2001 Parts in my garage. KYR SCCA member and Rally Driver wannabe. |
