Wiring diagram of Stock audio system
Hi all....
are anyone is having the wiring diagram of our stock audio system... like how many pre-outs we are having, like r we having the same outputs for both front/rear left and front/rear right or front (one output for both) or rear(one output for both). which output is given to tweeters.. if anyone is having a picture of wiring diagram please send it to me .... thanks, Pavan. |
no pre-outs. the front speaker wires from the head unit are full bandwidth. The door speakers have no attentuation, the tweeters have a 6dB filter to cut the lows, they branch between doors and dash in/around the kick panels
not a drawing, but maybe will help Constant 12V+ Red/Green Switched 12V+ Blue/Yellow Ground Black Illumination Red Antenna Trigger Red/White Antenna Left Rear Front Speakers Doors Left Front (+) Yellow Left Front (-) Blue/Red Right Front (+) White Right Front (-) Blue/Black Rear Speakers Rear Deck Left Rear (+) Yellow/White Left Rear (-) Blue/Red Right Rear (+) White/Blue Right Rear (-) Blue/Black |
or you could get the adapter that is made for converting it to another headunit...which is alot easier. I done it to both of mine
Hi,
thanks a lot guys, ok here is the thing... i am plannin to install a kenwood equaliser and as u know it is having only two inputs left and right. but from wht u r tellin, our head units r having Front Speakers Doors Left Front (+) Yellow Left Front (-) Blue/Red Right Front (+) White Right Front (-) Blue/Black Rear Speakers Rear Deck Left Rear (+) Yellow/White Left Rear (-) Blue/Red Right Rear (+) White/Blue Right Rear (-) Blue/Black so how can i connect to my equaliser... these many wires. here is the picture of it....i have marked the inputs in red please help me how to fix this, i am new to this field... thanks, Pavan. |
you will have to purchase what are known as line drivers. They will take the high-level speaker inputs (I assume you would use the front speaker set) and convert them to RCA level outputs, these then will go into the equalizer's inputs. The rear output of the head unit is not used with this drawing as there are only two inputs to the equalizer. You must then employ an amplifier(s) to drive the front/rear speakers from what appears to be the RCA outputs of the equalizer. Alternately, you could leave the rear speakers connected to the head unit, but they will then not receive any benefit of equalization.
get a new headunit w/adapter and then go from there. You can hook up almost anything from it. Most newer headunits have rca ins &outs if its decent. It will be worth it, you will not have to go through the trouble of rewiring everything from your stocker, plus you get to listen to your music instead of having a dead stereo because of some wrong wiring
