Practical Weight Reduction?
My SVX needs a diet. any *inexpensive* ideas?
standard:
remove sound deadening, remove unnesicary parts, trim pieces, heavy things, get lightweight battery, run on half a tank of gas, remove back seats, get lightweight versions of your parts, this can be more pricy, but i know that there are cf hoods out there, someone should make cf fenders, and such, do they have a lightweight jdm bumper beam for the svx? i also understand that the svx is screw crazy, they overscrewed everything, you can probably remove half the screws in the car you can remove your spare and tool kit if you want to get more expensive you can replace all the glass w/ plexi you can cut unimportant pieces of the car off, you can get thinner glass for the car if you want to go custom you can get lightweight everything i dont' know what model you have, but power seats weight alot, switch to some lightweight race seats, i also understand thta the ac int he svx is extreemly heavy, remove it do a manual swap, they're lighter than the auto if you want to get extreme replace all the body panels w/ anodized aluminum and don't paint it that'll shave some weight
SV What? |
Don't forget, you can also remove the ABS system. The brakes will still work you just get rid of all the junk to keep them from locking up on slippery surfaces.
All the stereo equipment and speakers... Remove the sunroof hardware and weld it closed...
cbx-man '92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter '92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft '80 Honda CBX in-line 24 valve 6 cylinder |
you guys are funny.
If you take off all of your wheels, that will decrease your rolling mass substantially!
i hear the engine is pretty heavy
SV What? |
...Or maybe YOU can go on the diet!!
Judging by the plate of enchelatas that Brad inhaled at chichis last night, i dont think a diet is gonna happen.
Ole. Mike. |
Of even more effect is the elimination of oscillating masses - I'd suggest the valves, pistons and connecting rods should go too - that should be an even bigger help. |
i think the best bet would be to remove the unibody...
it's a BIG piece of METAL metal is heavy lots of it is heavier, so remove the unibody, an dyou'll have one fast car
SV What? |
You definately don't need the wipers!
...or the visors or steering wheel.
yeah... but are there any REAL ways to lighten the car, that aren't extreme. I mean, 36-3800 lbs is WAY to heavy for 230hp. is there anyway to lighten the frame? but keep the interior the same?
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
I think I can lighten the car by 25-30 lbs. All it will take is me going on a diet. I'm sure the drivers seat will appreciate that.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
I'v had wet dreams about forged aluminum subframes and control arms. ohhhhh.
