EJ22 Turbo pistons
I want to build a turbo svx motor and the idea of fitting these pistons greatly appeal to me over forged custom pistons. As you all know There is no documented fact of this ever been done. I would like to change that. All I need to discover this possibility is a used svx piston in a standard bore B or C.
I have a 2.2 turbo shortblock ready to fit it into. If anyone knows where i can get this svx piston please let me know. |
i doubt they are the same bore
They ARE the same bore and stroke....
the EG33 is basically a EJ22 with 2 more cylinders
Good Project
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
Ps
Came in late on this conversation. My comment refers to Legacy turbo 2.2 pistons.
I went ahead and made all the appropriate measurements of the SVX combustiion chamber. The confusion about earlier measurements seems to be because the svx piston goes .018" out of the hole. Unfortunately the none of the 2.2 pistons will be appropriate for use in the svx. Before even bothering with calculating the resulting compression it's obvious that the squish area would be rendered ineffective if switching to the 2.2 pistons. I'm doing a full write up in a seperate thread in the supercharger section.
I just paypaled tomsvx he's got the piston. Yes the bore and stroke are the same but if the rods are different it might not work. as soon as i get this piston i will be able to find out for sure. Ill post the results.
It will go out on Monday after the holiday weekend is over... sorry for the delay
Tom |
Thanks Tom, Im in no hurry.
if you need anything else i have a stripped motor i can donate some parts.
92 LS-L been sitting for 6 years. 86 fiero gt, t-tops, 3800sc, headers, intercooler, p&p blower and lower intake, 3.0 pulley, 1.6RR's, double roller timing chain, xp cam, 130lb valve springs and hooisers :P 87 starion- currently rides on jackstands. |
Dan Pentiums - Melt in your PC, not in your hand! Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete. His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing. Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing. Mods: PWR Radiator! Problems: Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too! Ticking from front of engine, passenger side - Stuck lifter? |
Thanks guys. Im waiting for the piston Tomsvx sent me. if it dosent have the pin i will need it too. I already took the heads and pistons off the 2.2 block. So far I have been comparing specs from the ej22 manual and the svx manual. the piston diameters,bore diameters and clearances are identical but I cant compare the piston pin diameter since the svx notes i have are missing that data. The 2.2 pin diameter is 22.994 - 23.000 mm. Can anyone confirm this to be the size of the svx pin? There are other things to compare as well like the piston skirt length and conecting rod width and length and if the piston sticks out past the deck. I cant wait to get the piston so i can install it on the 2.2 block and answer all these questions.
I shipped the piston all the rings on it... the pin and the circlips that hold the pin in
Tom |
From the top of the pin Journal to the top of the piston- 22.16mm
" " hump- 23.04mm doing simple subtraction the hump is .88mm At the widest point at the base of the hump- 80.78 " " top of the hump- 78.53 Hope this is all you need Tom Last edited by TomsSVX; 12-24-2005 at 09:38 AM. |
