auto seatbelt issues
Here's what's going on:
When I turn my car off and open the door, the auto seatbelt thing just stays there. But, when I turn the car on, it works. Any thoughts on this? I was thinking a relay somewhere may have gone bad. But I dont know where the relays are in this car yet |
Automatic trouble
Everclear,
I don't have this type of belt, but the manual indicates the control unit for the auto shoulder belt is under the rear window shelf, approx in the centre. It seems to be a flat rectangular box facing fore-aft, with a wiring loom into each end. This contains both of the relays, L1 and L2. Your problem might also be simpler than this, there is a limit switch at each end of the travel of the guide. If either of these was loose, bad earth, the signal to switch relays, and so to change direction, might be confused. Worth your while checking these are tight and working. After that, check your control box. Hope this helps Joe
Re: Automatic trouble
well, the problem seams to have fixed it's self! it now works fine
thank you subaru gods |
I seem to have a simular problem. If I open the door when the car is still runing, the belt travels forward. If I turn off the key, it usually does not move unless I turn the key back on. It never has a problem traveling to the back position. I might check these switches myself, seems to have the problem at the one position only (back).
Re: Re: Automatic fix
Don't forget, if you have to do a repair on the belt in the future to only use genyoowine Subaru parts, none of that upgrade or modified tosh!! Joe
Re: Re: Re: Automatic fix
I'm back on good terms w/ my uncle, hense I get access to his junk yards. I hope he's got a SVX somewhere in there! Free subie stuff FYI, were putting his junk yards online, hense place an order and have a semi used, but working, part at your door in a few days for a fraction of the cost any of you guys have an idea for a domain name? |
Re: Re: Re: Re: Automatic fix
Part-ners.com??
My auto seatbelt will not work sometimes (1 in 20). What I've noticed happening is that the belt is stuck in the locked position. I just give it a little push (outward, not upward) and it works fine.
Any advice? CUrly
'92 Touring Ebony |
I don't really know but I guess the belt could be turned off inthe locked position and then just use the belt manually. That would solve the decapation problem.
I am having the same problem. I am tring to check the connections, and lube the track as well as some other things. If anyone figures this out, please post. I have just gotten used to opening the door before I shut off the ignition. If I forget, I have to pick my head up off of the ground. Sooner or later I may learn, or get it fixed.
auto seatbelts.....
Don't you just hate em'?......
Tom 92 Liquid Silver LSL 85 BRAT GL 81 280ZX 91 Legacy wagon 86 Pontiac Parisenne (55k) 86 Kawasaki ZG 1000 Concours 81 KZ 1000 LTD (shaft) |
Yeah but the ones in the Volkswagons were the worst. Remember those? When you opened the door, the whole thing would stretch out.
'92 Touring Ebony |
My driver side belt has been doing the same thing. When the car is running it opens fine, however when the car is shut off sometimes it opens like it should, other times it is delays maybe 5-10 seconds and then opens fine. I have have noticed depending on the humidity the belt seems to wait longer.
Michael 1992 SVX Build 4/91 SOLD TO gsodonis 2002 Civic Si SOLD 2005 Lancer Evolution VIII TRADED 2008 STi |
You know? I am really glad this thread got started My life with the shoulder belt has gotten a lot better. I unclip the shoulder belt before I get out of the car I put on the lap belt and the shoulder belt when I get in the car. This great Now I don't have to wait for the shoulder belt to get out of the way before I get out of the car.
