Possible alternator or wiper or connection issue
When I got into my very cold car (5F) in the morning, the wipers didn't work, at first. As the car warmed up I could get the intermittent setting to work but not slow or fast. As it warmed up more it started to work normally, sort of. I noticed that engine RPM had an impact. I also noticed that whenever I push the wiper fluid button, the wipers ALWAYS start immediately. To me, this sounds like an issue with the wiper controller but it could still be a an alternator or connection problem.
The battery is only a year old but when I left it at the mechanic for 2 weeks to get the wheel bearing and coil pack done while I was on vacation, the battery got too weak to start the car. Was it the 2 weeks in the cold or was it just not charged enough due to an issue, who knows? I connected my PC to the SSM and monitored the ECU voltage on my 20 minute drive this morning. When cold, and nothing on, the voltage was 13.9-14.0V. When I started driving I turned on the rear defroster and I saw that the voltage stayed between 13.8 and 14.0V on the whole drive. When I stopped the voltage was still between 13.7V and 13.8V at idle. The defroster was off at this point. I turned on the headlights and the voltage dropped to about 12.5V. I turned the defroster back on and the voltage dropped to 11.9V. Do these voltages seem reasonable? I checked the battery terminals and they seemed pretty clean and tight. If it is the alternator, has anyone tried the alternator below for an extended period of time an/or miles? https://www.amazon.com/dp/B007XUI7D2...v_ov_lig_dp_it
Re: Possible alternator or wiper or connection issue
For the temperature those numbers seem about right. I like to see 14.2 to 14.3 volts. Cold does nasty things to a car.
When your car is running the inside gets nice and warm, also humid from all the melted snow on the floor. As it cools down at night all this moisture condenses and freezes on everything including connections and switches and of course the windshield.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, Last edited by Blacky; 01-23-2020 at 05:33 AM. |
It is in the 20s this morning. Will see how they work today. I may try simply cleaning the connectors first.
Well, still did it in the mid-20s. Electrically, everything seems to check out in the car. I am suspecting the module and connectors.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 01-24-2020 at 12:58 AM. |
