$3 Airbox Mod!
This mod will work for both stock SVXs as well as ones in which owners have modified the intake resonator by removing the bottom section. It serves two main purposes:
1) Almost completely seals the airbox from the hot engine air (there's a tiny ball-point sized hole that sits in the lower section of the airbox to allow any water that gets into your airbox to drain out. I did NOT plug this hole) 2) If you've fabricated a ram-air system, it will operate much more efficiently (less pressure drop when forced air enters airbox - as it cannot escape into the engine bay but is forced through the air filter into the engine!) This mod takes about 1/2 hour to do and on a difficulty scale of 1-10 (10 is most difficult), I'd rate this as a 1. If you can change your air filter and turn a socket wrench, you can do this mod! The intake resonator, shown below, sits inside the passenger-side fender of the SVX. It runs in a U-shape from a point directly behind the turn signal, to a point just inside of the airbox: The portion that terminates at the airbox, doesn't form a seal of any kind with a rubber ring that goes around the opening. To do this mod, you'll need a socket wrench, 10mm socket and extension, as well as the $3 water-proof wrapping tape from your local hardware store/ Walmart. Step 1: Remove the entire upper and lower portion of the airbox. The lower portion is held down by two 10mm bolts on a bracket, and rubber piece that sticks into the fender. The portion of the resonator that sticks into the airbox will be clearly visible: Step 2: Take the 'rubbery' wrapping tape and wrap it around the 1 inch tip of the resonator. Step 3: Test fit the bottom portion of the airbox with the wrapped end of the resonator. Check for a tight, snug, air-tight fit! (if still loose, put more wrap around the resonator until the fit is snug) Step 4: Re-assembe the airbox. You're all done!!!! -Chike P.S. I took my car for a drive afterwards. Nothing felt much different but above 90+mph on the interstate I did notice a much "stronger" intake induction noise than before. I have modified my intake resonator so that only the top 6 inches remain and I've cut it so that the opening is flush with the front of the car. I'm not sure if it I'm getting a true ram-air effect at high speeds, but this mod will definitely help keep 160+ degree engine bay heat out of my intake.
If I have that tape already, is it still a $3.00 mod. If I can do more than one with the tape, is it a $3.00 mod?
Good write up. I will get it into the How-To Docs.
I'm assuming that you left some of the piping after the airbox in the fender? I've had a few different intakes on my svx and found the stock setup actually works better than any mods without the airbox. Not stating you removed your airbox. I had this idea, I'm not going to do it, I just thought I'd throw it out there. Leave the stock airbox and add a cone filter right after the airbox in the fender. Take your airbox filter and tear out the filter leaving only the foam rubber part to keep a good seal on the airbox. This will give you a the benifit of the larger filter area (cone) and the proper air pressure areas (airbox).
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 10-02-2005 at 08:32 PM. |
Thanks Earl. I look forward to seeing it in the How-To Docs! -Chike
-Chike
Good job, Chi ke!
Cool air is a cool idea!
Hah!! You think Chi-Kay's mod is sliced bread... well, I just sent my $99.95 check to Ripimoff Industries for their patented DRI-ice BlastAIR air box Enhancement System. They guarantee that by simply dropping their patented 6 inch square of something called dry ice into my stock air box, an ambient temperature of minus 109 degrees (that's colder'n a brass toilet seat in the Yukon), will give me a 0-60 time of 4 seconds, & over 35 miles per gallon at a top speed of 180 mph!!! Boy, that's worth the 6 month back-order wait for this marvel. Just wait 'til the Batmobile shows its stuff on the strip. Bwa-ha-ha-ha!!! Ron (ignoring "your manifold may shatter" warning).
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. Last edited by Ron Mummert; 10-04-2005 at 09:53 PM. |
1992 Midnight Black LS-L - Sold 3/3/06 1991 Toyota MR2 - Sold 11/27/07 1992 BMW 325i - Tokicko Suspension |
Nice. Good ol' Ripimoff Industries to the rescue...
-Chike
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
I wonder what would happen if you put dry ice in your intake box.....
All I know is I'm not gonna try it --mike
Early deceased SVXWN Member July 1986 -- February 2007 Michael - Duct Tape Man 1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit 1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something. "It's only after we've lost everything that we're free to do anything" - Fight Club "This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X |
You'd probably lose power. You may as well run your exhaust into your intake as forced induction
David, would like this write-up for the SVXipedia? Can you use the pdf file that Earl created in the How-to Docs? -Chike
It's easier for you to submit it.
That's how I designed the SVXipedia...built and maintained by the people, for the people
-Chike
Thread Tools | |
Display Modes | |
