Can't start the car
I had my fuel lines replaced above the tank. Now my mechanic can't start the car. Any suggestions?
Re: Can't start the car
Does it crank and not start? Or not crank at all?
If it cranks, first thing I'd check is what was being worked on. - Is it getting fuel? - Check the wiring back at the tank.
Sounds like he disconnected the fuel pump or hooked up the tubes backwards . See if you here the pump running when you turn on the key. U may have to listen inside the trunk.
He said it turns but won't start. He is getting fuel pressure to the engine. He is asking if there is some computer reset or something similar about this vehicle that he is unaware of. Thanks.
