Cross member as a jack point?
I've been using the cross member to jack up the front of the car and putting the jack stands on the two parts of the frame on either side of the cross member, is that a bad thing? I've noticed some indentations on the cross member, i just hope i haven't messed anything up. I have the manuals which show the jack points but i am just to leary of the jacks going straight through the floor panels!!
the engine crossmember? Its fine to jack from there
the little tension bar slightly behind that which could be considered a crossmember...your asking to be crushed the transmission crossmember....too far under the car to jack from, and even if you could reach it...dont bother. its not that sturdy the factory jack points are right along the car's frame rails (unibody style) theres no way they will get messed up. When jacking the car up (And ive done this plenty enough) I jack by the jack points, engine crosmember, and the rear diff, and in the case of my fwd svx, the rear tow hook
I jack mine at the front tow hooks...they were already folded and bent over when I bought the car, so it works for me and I don't have to run the jack too far under the car.
front wheels
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
I use the front suspension crossmember all the time. I always put a block of 1x4 pine between the jack and the crossmember. Watch out for the PS lines behind the crossmember. If you hit those, you could tear out a PS line.
'92 JDM (E) Burgandy/Black 100Km Just Crusin' |
(see group buy forum)
