alternator broke down!!
Hi
Unfortunately my alternator broke down There is no replacement in Holland available (regulator) at what price are they available in the US and how soon can you send it?? Autopartswarehouse (Autotrust) OT perhaps??? Subaruparts? Thanks for your help Rinus The netherlands Last edited by subaru; 12-29-2010 at 05:37 AM. |
Re: alternator broke down!!
The shops can rebuilt, but do not have the required regulator That's why I am asking you in the US Thanks Rinus |
Have you tried another shop? It is just a standard Mitsu alternator. Very common here, I would suspect it would cross over to something sold over there as well.
The shipping is $75.00 for the complete alternator. She can only pay the return shipping on US Orders. .
Many thanks for your comments
Still waiting for a call of the local shop Else I will order it at Christian Wishing you all a very lovely newyear's eve and a sparkling New Year Rinus |
After having fun for 2 days with the repaired svx suddenly at night there was a terrible noise from under the car and the feeling that a wheel would come off
Slowly to the nearest gasstation and got nearly stuck in the soft sidebanks of the road (fortunately 4WD) I have the car towed back to my garage. Wheels were good only closer inspection revealed a broken rubber manchet around the knuckle of the driveshaft left front (hope I described well enough) So probably the knuckle is toast I will hear today |
Slowly to the nearest gasstation and got nearly stuck in the soft sidebanks of the road (fortunately 4WD) I have the car towed back to my garage. Wheels were good only closer inspection revealed a broken rubber manchet around the knuckle of the driveshaft left front (hope I described well enough) So probably the knuckle is toast I will hear today from him By the way, is a knuckle replacable or do I need a complete driveshaft (with both knuckles) Rinus |
Your cheapest and most reliable alternator with high-end German regulators can be found HERE. You can't do better than this. Contact Christian at christian@maniacelectricmotors.com Your final price is only $89.00 US (EUR 67.74), after you return your old core for a $60.00 credit. With the money you save, you can afford expedited shipping to the Netherlands. For comparison, Autopartswarehouse choices can be found HERE Subaruparts.com can be found HERE Good luck .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 12-29-2010 at 06:31 AM. |
Oh and so now you're touting it as the most reliable. Give me a fing break.
Add into the formula their extremely reasonable pricing. They can't afford to have reliability problems that eat into their profits. Every alternator that leaves their shop is thoroughly rebuilt, inspected and tested by people who know what they are doing. .
I just shipped an 8 lb. package Priority Mail to Holland for US$68.00. United Parcel Service wanted US$167.00. Local would be better if possible.
Gene
Keith |
Yeah, I like having my warranty from a company 10k miles away too so my car can sit in the garage for 4 weeks while I wait for a new part. Glad to see you back Keith. Good Xmas?
