Old 08-29-2015, 11:46 AM
bishop bishop is offline
PnP heads while doing head gaskets
So while I had my engine apart to do headgaskets I decided to sit down with the heads and do some mild port and polishing work, I know its a little rough in some places but my machine shop said they were pretty good for a home job. These are not off the motor in the car but a spare motor.
Old 08-29-2015, 11:47 AM
Re: PnP heads while doing head gaskets
Dyno sheet coming soon.
Old 07-22-2016, 01:20 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Bishop did you ever finish/install this engine? Dyno sheets?
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 02-28-2017, 03:03 AM
finished installing the engine, sadly never got a chance to do dyno runs as the radiator failed catastrophically leading to a really bad overheat. I havent had a chance to start digging into the engine yet to see if it failed at the headgaskets or if the heads themselves warped.
