Old 01-19-2022, 08:11 AM
Lucaru's Avatar
Lucaru Lucaru is offline
Timing belts?
Where does one find a timing belt kit or pieces to make my own kit for an SVX?
I know EG's have some parts from an EJ but I'm not sure if timing falls under that same category. Any help will be appreciated!
1992 SVX LSL 4.44 swapped
1999 2.5RS coupe USDM EJ205 Swapped
2012 Impreza sedan CVT
R.I.P
2008 Impreza hatchback 2.5NA (totalled)
Old 01-19-2022, 01:42 PM
irox irox is offline
Re: Timing belts?
Like this one:
https://www.ebay.com/itm/360437374418
Old 01-20-2022, 10:31 AM
Lucaru's Avatar
Re: Timing belts?
Thanks for the help. Seems like a decent kit!
R.I.P
Old 01-20-2022, 12:51 PM
Re: Timing belts?
Here's a thread on a more complete parts list for a timing belt change:
http://www.subaru-svx.net/forum/showthread.php?t=65142
There are some things that generally don't get included in those kits that might be nice to change anyway (like the timing belt cover gasket).
Cheers!
Old 01-21-2022, 07:47 AM
Lucaru's Avatar
Re: Timing belts?
Thanks for the help!
slightly off topic would you happen to know if the size and pitch of the transmission drain bolt is the same as the engine drain bolt?
going to get a sensor for ATF temp and want to get a tapped bolt
Thanks again for the help with the timing
R.I.P
