Old 08-17-2010, 01:02 AM
tigersvx's Avatar
tigersvx tigersvx is offline
1992 SVX WHITEPEARL
help,turn key to start,no sound
my 92 svx happened from time to time,about 20-30% of time,
when i turn the key to start,all the lights show,but when turn key
further to start,no sound at all.
Before,i have to try again,and it usually starts after the 2-3 times.
Today,i went up to the snow parking lot,0 degrees cel.,and take me 6-7 times to start.
Is this the starter problem?or something else?
Is someone has a spare for sale?Thanks.
1992 SVX whitepearl 129,000km
2005 MAZDA3 red 38,000km
2001 HYUNDAI XG V6.3000
2003 TOYOTA PREVIA
Old 08-17-2010, 08:23 AM
processengr's Avatar
Re: help,turn key to start,no sound
You will want to do a search on this, try seaching for "starter relay bypass"
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 08-17-2010, 08:35 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Could be the neutral safety switch, which is the mechanism that prevents starting the car in any drive gear. Try shifting into Neutral next time this happens and see if starts then.
Old 08-17-2010, 09:10 AM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
Send a message via AIM to cozykat Send a message via MSN to cozykat Send a message via Yahoo to cozykat
Agreed. Test for this first.
It's either the ignition relay or the park-neutral safety switch. The ignition relay goes through your steering wheel and is a bugger to replace but not totally terrible. The park-neutral safety switch is located underneath your center console (like directly below the emergency brake) and probably easier to fix.. just depends on how easy it would be to move/remove the center console off.
A while back, I had an ignition switch issue and with that fixed.. now, I think I too suffer from the neutral switch issue.
Marisa
'93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior
'92 Pearl - 100k Side restoration project
Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram
Old 08-17-2010, 02:59 PM
tigersvx's Avatar
1992 SVX WHITEPEARL
Thanks you all for responding so fast,its great to have all svx fans,
Ill check all to see.
Thanks cozykat,could you tell me about your ignition issue?
cos at first i thought it was my loosen ignition switch that present the problem,after the cover came out,there was a screw that hold the switch
that was lossen,.But after tightened,the problem still exist.
So,may be i hav to check the relay first.
thanks.
SO,if anyone know how to test a starter motor to see if its good or bad?
and how to test a bad relay?
sorry,i just a novice.
THANKS ALL,THE BEST.
2003 TOYOTA PREVIA
Old 08-17-2010, 03:11 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
thanks.
So you DID try starting in Neutral(N) with no luck?
Old 08-17-2010, 06:18 PM
oab_au oab_au is offline
thanks.
Tiger your model does not have the relay under the dash as Lee says, this is only on the US models.
You need to fit a 30 amp Bosch relay to the starter solenoid that is on the starter motor. Any auto electrical shop will know what this is and fit it for you.
This a link to the way it is fitted.
http://www.subaru-svx.net/forum/show...1&postcount=23
One Arm Bloke.
Tell it like it is!
Old 08-17-2010, 09:35 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Better to fix the real problem instead of bypassing it. Replace the starter relay. It's held in position by the steering column bolt. DO NOT totally remove the bolt. Just loosen and the relay should have a slot that permits pulling it down so it can be removed.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
(+6 with other members of the family)
FREEDOM IS NOT FREE
