Old 08-02-2008, 11:14 AM
TurboIQ TurboIQ is offline
Exclamation Shifter moves freely, car won't start. Please help!
After not having used my SVX for 5 days, I started the car this morning. Everything seemed fine.
After having let it warm up, I pressed the brake and put the shifter in reverse. To my surprise, the shifter was moving freely and effortlessly in all gear (I could barely feel the gear notches) and the car wouldn't go into any gear.
Since I was parked in a slight slope, the car was slowly going backwards, but without any resistance from the engine or transmission, regardless of what gear it was in. So I stopped the engine and put the hand brake back on. Then the car wouldn't start, period. I could no more hear the brake release solenoid when I depressed the brake pedal (it worked fine 5 minutes before), so the shifter was stuck in park. Since the shift lock release didn't seem to allow me to shift into neutral, I dismounted the whole center console to get acces to the shifter mechanism (yes, maybe it was useless).
One thing I did notice while trying to get the engine started (besides the fuel pump priming) was a constant buzzing noise (like a stuck bee) comming from under the car. I think it has to do with the transmission in some way (maybe the valve body solenoids) because when I unpluged one of the harnesses that goes to the TCU, the buzzing stopped.
What are your ideas, and what should be my next move?
Old 08-02-2008, 12:19 PM
kwren's Avatar
kwren kwren is offline
Re: Shifter moves freely, car won't start. Please help!
Sounds like some linkage came loose from the shifter... At the very least a shifter problem.
Take a good luck at what goes on with the inhibitor switch when the shifter is moved. The inhibitor switch would prevent start but probably because it isn't rotated properly, not that it is defective.
I think it is moved mechanically with the shifter, so not moved to one of the start positions is a clue. Wouldn't think it is a big problem to check out and get going... Sure hope not!
We are pulling for you!!!
Keith
Old 08-02-2008, 01:24 PM
Awsome!! I'll start with that and we'll go from there. Thanks Kwren.
Old 08-02-2008, 01:41 PM
w.c.myers w.c.myers is offline
it sounds like the shift lever on transmission is not moveing.it located pass side of tran you might want climb under car have someone move shifter and see if lever on tran moves back and forth if it doesn't cable might be broke
Old 08-02-2008, 06:48 PM
Your shifter cable is most likely broken....
Old 08-05-2008, 06:28 AM
You guys were right on. The cable broke at the very end of the shifter. Anyone know the part number?
EDIT: never mind. I did a bit of search and found "35151PA000" on the SubaruParts.com web site. 66$. Thanks to you all for the help. Hopefully, another problem solved.
Old 08-05-2008, 08:03 AM
Glad you got it figured out...
I'm guessing that the cable out of a Legacy will work too, as they use the same style shifter/tranny combo...if you wanted to pick up a used one..
Old 08-05-2008, 03:35 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Since the 5 spd linkages need to be extended doesn't it make sense that the SVX shifter cable would also be about 2-3" longer???
I'm not sure, just thinking out loud...
