idling issue.....
well..my engine idles very weird...it bogs up and down at idle...at some point it'll idle fine...but then...idle weird...sometimes when im actually driving and then coming to a stop..it'll idle up and down then dies.....anyone had this before??
thanks dao |
First thing i would check is all your vacuum lines. There are alot of them even under intake. If your engine has miles on it alot some of the lines might be dry, cracked or loose. I had idle problems and stall problems! They were both related to vacuum lines problems!!!! Look at the one behind the p/s pump under intake. That one drove me nuts and was the main cause of my idle problem.I would also check you intake bolts make sure there tight. I found four of mine loose before!
steve |
