Anyone have a favorite tranny cooler and pics/instructions on howand where to install one?
I dont want to buy one at pepboys that doest fit and have to return it. I also figure I should do this before any other modsm
Henry Yei htyei@svxwrx.com 1992 Dark Teal LS-L w/o spoiler "OLIVIA" http://www.svxwrx.com |
more questions
Do a search on Yahoo for tranny cooler then come back and read the rest of this post .
I was just searching around and I found a lot of nice ideas on what transmission coolers to use and where to mount them but I could not find anyone agreeing on anything. Is putting the tranny cooler in front of the radiator just as good as the other various places people were mounting them? It also seemed like no one could agree on whether to put the cooler in series with the stock cooler or bypass it all together. If putting it in series is the way to go can I assume it would come after the Subaru cooler? It also sounded like the main reason for installing an aftermarket cooler is because the Subaru one tends to get clogged after a while. I got a new radiator about 6 months ago (it was cracked) along with the external transmission filter replaced and the ATF changed. Should I still consider putting in an aftermarket cooler? |
Have you considered putting the cooler in parallel with the existing cooler? I don't think you want to put them in series. If the stock cooler plugs, then your aftermarket cooler becomes useless. And why bypass the stock cooler, and thus lose whatever cooling it has to offer, if you bypass it completely.
I've just finished installing the B&M auxillary filter and transmission temperature gauge. After I've collected enough temperature data, I plan on installing a B&M cooler. When the cooler does go in, it will be in parallel. Just my take on the subject.
bill Green 95 SVX - Cleo Green 97 Outback - Maxine Red F-150 Extended Cab Long Bed - Big Boy Even the best monkey sometimes drops his banana. |
sure do
B&M Supercooler #70268 is the biggest and best cooler you can fit aft the radiator.....very strongly recamended. ITs for vehicles 19000-24000 lbs! Make sure you partially cover it up oin winter though, the tranny does need some heat.
phast
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
more questions
Re: sure do
Just to clarify: My tranny rebuilder was the one who recommended the parallel set-up. This guy's in his latter 40's and he's the third generation owner of the shop that his grandfather started and his dad passed down to him. I asked him about the flow loss -- he said that any flow loss would be negligible.
My experience is, that the cooler must be doing its job. After installation, I noticed that it took longer for the TC to kick in (engages when tranny fluid reaches 50 degrees F). I could set my clock by it on the way to work in the morning. I would feel it kick in about five miles down the road. After installation, I was almost finished with my 40 mile trek to work before it kicked in. If flow was being restricted, the temp would rise quicker and the TC would kick in sooner. So, I figure the expertise of a lifetime tranny man will negate the shade tree modifier any day of the week. But then, that's only my opinion.
Thanks for the info aredubjay. Just to aid in my on going quest for transmission info: what cooler did you get and where is it mounted?
Thanks again. |
I can't remember what kind of cooler it is. It is small and mounted just behind the air dam, in front of the AC condensor. It gets full air from the opening in the bottom of the air dam. Good luck in your quest.
My info
I have some info on this, I will post it tonight when I have more time.
Mike 92 LSL Teal 103k 00 RS 2.5 Silverthorn Metallic 36k 68 Chevy Camaro 07 Forester XT Sport |
Me and kastle have Hayden tranny coolers sandwiched between the A/C condensor and the radiator. Which allows for a very large tranny cooler. I don't like to run it to the radiator A good sized tranny cooler is more than adequate and does not need to be run through the radiator
Re: more questions
i'll be sure to post the results.
I have the perma cool with fan as well as the B&M - I got the perma cool after running with just the B&M for a while and watching the temp gauge sit at high temps in stop and go traffic. If you live in a hot climate you should really look into getting the fan. I do not need the fan turned on under about 65 degrees ambient temp but above that the tranny will get hot. The stock cooler is bypassed. Pictures in my yahoo briefcase.
I got the B&M and temp gauge and filter kit from summit. The filter kit is summit with a purolator pure one filter, the temp gauge is autometer. There is a hole tapped in the filter kit housing for the temp gauges sending unit. I ordered the perma cool direct from Perma-cool. Jegs also sells them.
When I first installed I had the stock cooler in series with the B&M and the temps were bad. Very hot, I dont rememebr how hot but it was ugly. A short ride would rocket the temp past 200. Keep in mind that that is in SC this past summer and it is normally 85 degrees out. It got better bypassing the stock cooler but would still get hot in traffic. The B&M alone did not reduce the temperature much when stopped. If it was at 205 when the light turned red it might be down to 200 when its time to go. There is hardly any airflow with just the stock A/C fan pulling air through the radiator and condenser. With the B&M and the perma cool it does still produce heat but it will quickly drop in temp either when cruising with torque converter locked or when at a traffic light stopped with the fan running. You will be amazed to watch the temp gauge rocket on a slow -torque converter unlocked and spinning up tons of friction - launch. The tranny produces less heat if you floor it and get up to speed quickly. The highest temp I have seen lately is 180 on a 70 degree day. Last weekend I drove to Pennsylvania at average speeds of 80- 100 through Va and W.Va and the temp stayed around 150 about the entire time - up and down the mountains, but the outside temp was about 45 and I was going fast enough that the torque converter didn't unlock on the steep hill climbs. A B&M alone would be fine if you could drive fast all day and never have to stop for a light. The fact is that these are all band-aids and the real solution is the valve body mod which I will surely have done if this tranny ever takes a dirt nap, but for my money and peace of mind there is no way I would go without a tranny cooler w/ fan in a warm climate on a stock tranny.
Matt Locker Link 2015 BRZ Limited 6MT 92 Ebony LS-L ECUtune Stage2av1, Z32 MAF, 370cc injectors, TomsSVX intake, BontragerWorks 22mm RSB #003, HID Hi and Lo beams, OT endlink and bushing mods, PWR Aluminum radiator, Harvey's QC shift kit, 2.5" flowmaster 80 exhaust, 17" Michelin Pilot Sport A/S, Poly sway bar bushings, Slotted Bradi rotors, AFBeefcake powdercoated calipers, 97 grill, and a huge set of air horns. 300,000 miles and counting 92 Ebony LS-L. ecutune stage1v4, motorsport 1pc pulley. Garage Queen - sold to Dad in upstate NY 155,000 miles 19 Subaru Ascent Premium - -Hers !. 89 DL 4x4 little red wagon - a.k.a. The immortal suby. 275k R.I.P. Last edited by immortal_suby; 03-21-2001 at 06:48 PM. |
