Knock Sensor questions
Stored codes from my teal SVX:
#22 knock sensor right #28 knock sensor left #37 oxygen sensor left The knock sensor code explanation reads, "Abnormal voltage in knock sensor monitor circuit." Questions: 1) Could some fault other than bad knock sensors affect the "monitor circuit"? 2) What's the likelihood that both knock sensors could fail pretty much simultaneously? CEL is intermittent and rarely on for 2-3 minutes of a 15-minute drive. Car runs fine. Fuel economy could be just a tad off. Thanks in advance. dcb |
Re: Knock Sensor questions
Did all 3 codes appear at the same time?
Some people have found that their timing belt was out of alignment which caused similar codes. I've seen knock sensors with the plastic shells broken but not throw errors. Have you done anything under the hood recently?
First got the CEL in March; stayed on just a couple of minutes near the end of a 100+ mile highway drive. Very intermittent since then but increasing in frequency. Seems more prevalent in stop-and-go driving than at cruise. Finally got around to checking for codes yesterday. First time I've had cause to pull codes from this car.
No major work lately. 57,000 miles on the timing belt. No knocking or missing or stumbling nor other obvious misbehavior to suggest jumped time. Thanks, dcb |
It wouldn't hurt to change them..they are not expensive, just maybe a bit time consuming. I found that my sensors both had cracked housings but they did not throw any codes. The connectors though were caked and sitting in oil due to standing oil under the intake plenum on my vehicle...perhaps the connections may be suspect?
162k. I'd say it's time.
