Restoration of Pearl 94 LSI - Electrical issues
So I'm restoring a 94 Pearl LSI. I'm halfway finished and some dash lights are throwing me a curve. I've read almost every post here regarding lights on the dash (including Trevors posts), but I still need some help. Here's the issue...
When the car is running, the Charging (Battery), Brake, and Stop Lamb dash lights are illuminated. I have swapped in 2 different alternators from 2 other SVX's and the lights are still on. I have unplugged the Alternator plug, while running and the lights go out...hurray! So its an alternator issue, right? Hang on, If I use that same alternator in my daily driver SVX, the dash lights do not illuminate and I read ~14.5 volts charging at the battery. The same alternator produces ~15.5 volts at the battery on the SVX with the dash lights on. I have tried a new battery, but not a new battery with a swapped in Alternator....hmm..I wonder if I have a bad battery too? O.K. next step is to test the battery's load response and/or swap the battery that I know is good from daily driver into the 94. Regardless, I would appreciate any input from those that have resolved a similar issue or any EE's, or really anyone for that matter, that wants to weigh in. Just looking to repair the issue so I can move on the remainder of restoration, repainting black top and trunk lid, replacing rusted sunroof drip tray, rear diff thumbing issue, oil leaks from valve covers, non functional AC, etc. Here are some other electrical issues I've noted.
Re: Restoration of Pearl 94 LSI - Electrical issues
sounds like it could be an ignition switch (electrical part) issue. try moving your key around in the cylinder when it happens and see if anything changes, or jump power from the battery directly to a fuse with power only when the key is on, if the lights go out then something is not getting good contact in the switch.
There is a separate wire that tells the alt what the battery voltage is. I would think this wire is open. it runs from the Ignition switch to the plug on the side of the alt. Read this bit on the alt from the WSM. Harvey.
After looking over the electrical service manual, as well as having discussions with Maniac Electric Motors and an accredited electrical engineer, here are my thoughts on this.
15.5V can be accepted as within normal commercial tolerances, as the electrical manual allows 16V. There should be no reason why 15.5V DC should cause the trouble lights in question to illuminate. The pilot voltage sensing wire referred to connects directly at the distribution box and is shown as "S" (sensing circuit) in the wiring diagram. It does not physically run to the ignition switch. The diagram is a only a schematic, and in any event this circuit should not cause the problem. The fault most likely involves the circuit marked "L", (the alternator fault indication circuit), which is closed if the alternator is not charging. This circuit normally illuminates the steering, stop check, brake and charging lights when connected to ground, via a transistor. But in this instance the steering light is not illuminated because the steering has been altered, as stated in the original post.. This wiring running between the alternator and dash and its connections should be checked for a short circuit, rather than an open circuit.I would pay particular attention to the area around the alternator, where damage is most likely to occur. Quote:
Simple logic tells me this: 2 different cars. Alternator works correctly in car 1 Alternator works incorrectly in car 2 Only thing common between the cars is the wiring. Therefore, problem exists in the wiring of car 2. I a not sure how much of a role the disconnected steering rack plug plays in all of this though. This is the only other difference. . Quote:
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-04-2011 at 07:09 AM. |
I think you guys are right on. I discussed this with my friend (Nissan master tech) last night and after going through the electrical diagrams he concurs that this is a short or bad connection (voltage drop) between the alt and the dash.
Thanks for the input. I'll let you guys know what I find and what the issue is once resolved. |
15.5 volts is not accepted as normal. No lead acid battery likes to be charged above 14.8 volts. The 16 volts that your accredited electrical engineer has read in the manual, is referring to the the failsafe 16 volt zener diode that is connected in the regulator circuit to prevent the voltage rising above 16 volts, to protect the cars electrical components, in the event that it no longer can read the battery voltage. It is the black/red wire in the plug on the side of the alt that reads the battery voltage. If the ignition is on there should be battery voltage on the wire. Harvey.
Harvey, sorry but you do have to guess who my electrical engineer friend is and he was trying to understand the actual reason for your post.
He and I read the page of the manual you posted. You are correct in saying that 15.5 volts is not accepted as normal, provided that the a normal battery is normally connected for normal charging. But as the manual shows the voltage can rise to 16 volts without there being an actual alternator fault, as this is the upper limit set by the regulator. By the way my friend points out that there is not a secondary fail-safe Zener diode within the regulator as you have described. As you said, there should be battery voltage on the wire, but what has all this to do with svxcuseme's problem and how can 15.5V-16V cause the indicator lights to come on as you said in your post? What is wrong with the advice that I have posted? .
This is the connection, I believe is related to Svxcueseme's problem. Harvey.
