Headlight leveling
Attempted to check the leveling on my headlights today, but the levels are definately off. I made it so both lights project at the same height but the left level says the light is too low and the right says its too high. Is there some type of a science to leveling the lights (ex. park 4ft from a wall, top of the beam should be 4ft above the ground)?
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 |
Yes there is. I have posted it before. I will search for it again and post it again. This is like the 4th time we had this question in the last 2-3 weeks.
L
Lwin M. Maung (Member # 147) Current SVX: NONE Previous SVXes: 1994 LE Barcelona Red 107k 1992 LS-L Pearl White 143k 1994 LSi Bordeaux Pearl 220k 1992 LS-L Ebony Pearl 184k 1992 LS-L Liquid Silver 145k 1992 LS-L Liquid Silver 102k 1992 LS-L Ebony Pearl 123k Other current cars:2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
Re: Headlight leveling
Just off the top of my head, I remember distinctly TWO specific instructions from the manual: A) Have a full tank of gas, B) Have someone sitting in the driver's seat. Other than that, I can't remember any specifics.
http://www.advanceautoparts.com/howt...20010801ha.htm
This sounds like the poor bastards who flash me when I'm running my fogs.
. Earl .... ... .... ><SVX(*> Subaru Ambassador [COLOR=silver]1992 Tri Color L[/COLOR] ~45K (06/91) #2430 1992 Dark Teal LS-L ~184K (05/91) #0739 1992 Claret LS-L ~196K (05/91) #0831 1992 Pearl LS-L ~103K (06/91) #1680 1992 Pearl LS-L ~151K (06/91) #2229 1992 Dark Teal LS ~150K (07/91) #3098 (parts car) 1992 White LS-L ~139K (08/92) #6913 1993 25th AE ~98K (02/93) #164 1993 25th AE ~58K (02/93) #176 1993 25th AE ~107K (02/93) #215 1993 25th AE ~162K (02/93) #223 1994 Laguna Blue Pearl LSi ~124K (1/94) #2408 1994 Laguna Blue Pearl LSi ~144K (10/93) #1484 1994 Laguna Blue Pearl LSi ~68K (10/93) #1525 1994 Barcelona Red LSi ~46K (02/94) #2624 1994 Pearl LSi ~41K (12/93) #1961 1995 Bordeaux Pearl LSi ~70K (02/95) #855 1996 Polo Green LSi ~95K (03/96) #872 1997 Bordeaux Pearl LSi ~55K (08/96) #097 2003 Brilliant Red LS1 Convertible ~29K (04/03) #8951 1999 Magnetic Red LS1 Coupe ~33K (04/99) #6420 My Email | Old Locker | New Locker | Picture of 15 of the 19 |
The levels are crap and will not help you! Try doing what I did:
-Fill tank up with gas -Park on level ground -Get to large white peg boards (3X5) and tape them together and set the bottoms of the boards on the floor, Get each headlight on each one of them - Turn on lights and start adjusting... It works relly well!! |
I did a search last night and found this site (Chicane listed this before):
http://lighting.mbz.org/tech/aim/aim.html
1996 Volkswagen Jetta Trek |
Thanks everybody, I did follow the instructions (actually I only had half a tank). To tell you the truth, there is no difference in the height of the lights or levels with or w/o me in the drivers seat. The problem is definately the levels, like I said exact same beam height, but completely different level readings. Right now my headlights kind of aim down too low because I wanted to be sure I wasn't blinding anyone. The sights landshark and manofmayo posted are exactly what I was looking for, thanks guys. So basically 25ft away=2-3in lower
P.S. I know I've read a post on this before (probably by Lwin), but for some reason search doesn't return any logical results. I tried "headlight leveling", "headlight level", and "leveling" but no luck, unless its hidden in some strange post.
headlight levels
There is a small screw on the levels that appears to hold the level glass on to the carrier attached to the headlight assembly. The screw is spring loaded from underneath and can be used to adjust the "level" of the level. I just set the headlights where I wanted them and then adjusted the small screw to center the bubble. Now its easy to return to the original level if I remove the headlight assy.
YMMV. Rob
1992 Dark Green LS-L @ 300,000 I'm only 2nd owner, Burns no oil!! Also in Family: '04 Nissan Murano, '98 Lex GS 400, '81 Accord, & '88 Civic w/ an Acura ZC engine. |
