Old 09-21-2011, 11:51 AM
Cam Cam is offline
Dash Lights
Recently some of the lights have been flashing on my dash. I believe they are the battery light, power steering, and a few others. The ABS light has not been flashing, but this morning all the lights that are normally flashing were SOLID as well as the ABS light.
Other than an alternator, is there anything else that could cause this?
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 09-21-2011, 12:22 PM
Re: Dash Lights
Bad grounds come to mind or bad connections to the battery/alternator.
Old 09-21-2011, 01:35 PM
Re: Dash Lights
bad ignition switch can cause it. common on later subarus. try wiggling the key to see if they blink or turn off.
