HELP! Tech assist required!
Hi all,
After returning from overseas, I have found that my air conditioning doesn't cool. I only had it re-gassed before I left, so it has all leaked out in 1 month. I took it back to the A/C specialists who tell me that one of the metal pipes that comes from the canister (just under hood behind RH headlight) is leaking, wither from a hole or from the PRESSURE SWITCHER. I am told the part I require is PN # 73052PA000. Subaru Australia want $225 for the part and the A/C people want to charge 3 hours labour for the repair and re-gas. HAS ANYONE HAD THIS PROBLEM AND HOW WAS IT RESOLVED? Does anyone know where I could find that part CHEAPER in Australia or Canada, as I will be in Canada most of May. Kindest regards,
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com |
Re: HELP! Tech assist required!
Hi Mike, it could be the pipe from the condenser that has cracked, to leak. I had this leak on mine, replaced the condenser. It was about 550/600 to buy here, 350 from the US.
Thanks for the prompt response, Harvey!
It was just fitted with the new dye, so the techs told me it is leaking from the pipe, not the condenser and that it was leaking near the pressure switcher - but without removing the radiator, they couldn't be sure. They tell me that if it is a hole, they can fix it. If it is a problem with the pressure switcher, they recommend I replace part. Cheers, Mike
How about that - I had the EXACT same problem on my Grey SVX about a year ago......
I found that the A/C compressor clutch was not being activated when the A/C was turned on. The Trinary Pressure Switch was open-circuit, indicating a low refrigerant charge. It turns out that the refrigerant had leaked from inside the switch itself! The internal seal inside the Trinary Switch had failed, allowing refrigerant to leak out from the body of the switch, where the electrical contact pins are. It was cheaper for me to replace that entire section of pipe, which includes a new switch. I purchased one from the USA (1stsubaruparts.com). It is very easy to replace that section of pipe - it comes with new o-rings on each end, so you simply unbolt the fittings at each end, and bolt the new pipe on. If your system is still running R-12 refrigerant, you will need to convert the system over to R-134a - this involves replacing the receiver / drier unit, and changing the compressor oil. Jason.
1992 Charcoal Grey SVX - 165,000km 1992 Ruby Red SVX - 165,000km ....now with sequential VIN numbers! 1986 Holden (Isuzu) Piazza Turbo - 225,000km 1993 Mercedes W140 S500 Coupe - 153,000km 1990 Mercedes W124 300D - 313,000km EG33 + 4EAT + VTD AWD = SVX |
Thanks Jason.
I have to go overseas for 3 weeks, but will sort it out when I get home. Mike
Yes, the switch has been a cause for leaks in the past. Not likely a pipe is leaking unless it is from a seal. Try replacing the trinary switch first
Tom |
Thanks again for the advise. Can the TRINARY switch be purchased seperately?
Should be able to. It is threaded into the block in the pipe
Tom |
