Roof window - does not lift from time to time
Hi guys, does anybody had the same problem? Mine roof window does not lift from time to time, to open it, I have to push it little bit. I have tried to align it, use a lot of lubricants but it seems it has some mechanical problem, maybe easy to solve. Thanx for any hint.
Petr
Petr "It is never bad enough, it could always be worse" |
yeah i gots that problem as well . It happens more often then not. Have to give it helping hand to open it, just a little push up. Yeah its been bugging me as well. I read some stuff about adjusting the clutch, but i don't know where it is. Any suggestions??
Some people have success with tightening that nut ever so slightly. The nut is under the round plastic cover in the roof liner.
Yup we have the same problem with our sunroof ( or moon roof as our Japanese friends might describe it, well they did in a Toyota manual ! ). Just have to give it a gentle push.
94 Aug M reg black UK SVX 97k miles, std car. For Sale 2003 530d Sport Auto BMW 75k miles and increasing Ford Racing Puma 2000 X 27k miles FOR SALE "Stranger from another planet welcome to our hole just strap on your guitar and we'll play some rock n roll" - The Stranglers Feb 1977 |
My mechanic tried to do it but no result. It moves OK the only problem is to lift it up...
Petr
I'm presuming your mechanic took away the plastic disc in the roof lining, and adjusted the clutch? It is commonly accepted that the motor gets "tired" with age, and the toughest part of its job is lifting the roof up from its fairly tight fit. If this is the case, then the cure would be either replacing the motor, or taking it apart and refurbishing it, lubrication, new brushes and so on. It strikes me that this would require taking the sunroof apart, and the roof lining, maybe more trouble than it is worth, to get at the motor. Recently I have read a thread in the USA. Beav, who knows his stuff, says that the packing material around the roof swells with wet weather, making the roof a tight fit, making it stick. His cure is to clean it thoroughly, and to use plenty of lubricant to make it easy to shift upwards. This seems to work for him. If it works for you, it is a solution. Otherwise, I would keep it lubricated and give it a nudge to kick up at the start. Unless you really really want to take it all apart? Joe
