Bleeding Brakes
What's the proper procedure for bleeding the SVX brakes?
Believe it's driver front, pass rear, driver rear, pass front.
Thanks I will try that. I've never done this before.
Buy yourself one of these.
If you don't disconnect the brake lines you shouldn't have to bleed them though. I just had my brakes all apart, no bleeding necessary, and i replaced my pads and rotors. Just use a c-clamp to recess the pistons back into the calipar if your changing the pads. Much easier and cleaner job that way.
Current: 95 svx Ls-L (Black) 91 5sp awd xt6 (red) Had: 91 xt auto awd(lt blue) 85 xt 4wd turbo 5sp(blue/white) 86 xt 2wd turbo 5sp(black) 85 xt 4wd turbo 5sp(silver/white) 89 xt AWD 5sp (white) 85 xt 4wd turbo 5 sp sold to Zukiru (silver) 86 xt turbo 2wd 5sp (silver/black) |
