Differential mounts removal
I undestood that I have to remove the differential to remove/install the new mounts.
The differential will come out without removing the rear CV's? In other words: There is enough play in the back CV's to get out the differential without removing them from the weel hub? I don't won't to touch the rear weel if it is possible. Thank you |
Yes, there is enough space/movement to remove the rear diff without touching wheels.
You have to disconnect the exhaust pipe (it is stainless, I was able to do mine with 146k mile). The diff is about 40 pounds, you do not want to leave it hanging on the drive shafts, and it will not be terribly stable on vehicle jack.... Removing the diff is relatively easy and straightforward. |
