Directions for water pump
What do I need to do to replace my water pump? Instructions ect...
John & I recently did my timing belt/water pump and photographed the procedure. I plan to put that together with the shop manual instructions and a list of parts including special tools (right John?) and gaskets for a complete guide.
The problem is I haven't found the time yet to write it up. Doug
<<Don't forget instructions on how to give your engine that "pretty pink glow.">>
That is a custom off road application I do not recommend for daily drivers Doug
Do you have to pull the engine out to get to the timing belt? About how long did it take you to do both things?
<<Do you have to pull the engine out to get to the timing belt?>>
No but removing the radiator is about the most removal other than the involved parts themselves <<About how long did it take you to do both things?>> We also installed a new radiator, transmission cooler, replaced all the hoses and belts and that took us about 5 hours I think. If you just replaced the timing belt and water pump, I would say for a first timer, plan 3-6 hours. If you buy the pulley wrench, cut an hour off of that. If you buy the sprocket wrench as well, subtract another 45 minutes. I don't have those tool part numbers handy, but I will get them tonight so someone can price them up. Doug
Crankshaft Pully Wrench 499977000 $171.06
Camshaft sprocket wrench 499207100 $0.00 I beleive they are both discontinued. Perhaps NAPA or some other parts store can get one for less $$$ Doing the job without them is possible, but plan on a lot of swearing. Doug
