Brake Fluid Change
I want to change the brake fluid in my brake system when I change the rotors (slightly warped) and pads later today (I hope). When changing the fluid should I pump all the fluid out first....until dry as possible in the system, before adding and bleeding the new brake fluid? [having to bleed alot of air out of the system] OR, should I bleed out the old fluid only until at the bottom of the master brake fluid reservoir....then adding the new brake fluid..to keep continuity of fluid, preventing air in the system?
THANKS! for your help...
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 09-18-2005 at 04:11 PM. |
Use your mom's turkey baster to get all the old fluid out of the reservoir. Clean the inside of the reservoir with paper towels to remove the stains and gunk from you old brake fluid if needed.
Fill with fresh fluid and bleed the brakes until clean fluid comes out.
Isn't there an order for bleeding? ex. drivers front, pass front etc.. I need to change my fluid, it's way overdue.
No particular order is required but generally things will go quicker if you begin with the farthest wheel first, progressing towards the closest, i.e. RR, LR, RF, LF.
Do you have to bleed the ABS pump?
The shop manual states that you should start with the two bleeder valves on the ABS box and then move to the back wheels, then the front (i.e. like Beav said...)
-Bill
Uh uh. Don't mess with the ABS bleeders, you could cause youself some grief. Just keep the master filled and bleed at the wheels. The only time you need to use the ABS bleeders is when you replace the ABS HCU. Trust me, FSMs don't always give you the best advice, especially when working on cars a few years out.
