Smoke!
My car is leaking oil from somewhere and it lands on my exhaust and causes a nice, embarrassing smoke screen at stop lights. I'm sick of the smell, and I'm even more sick of holding my head in shame as other cars look in horror as my car appears to be on fire. The symptoms are more pronounced when I come to a stop at the end of a long highway drive. Is this a common problem? Is it easily fixed? Thanks in advance for the help.
Clarke |
This is not normal. Easy fix? It depends on where the oil is coming from. It could be as easy as your power steering fluid, but could be oil from somewhere else. I would clean the engine and figure out where the oil is leaking first and then go from there. Good luck.
. Earl .... ... .... ><SVX(*> Subaru Ambassador [COLOR=silver]1992 Tri Color L[/COLOR] ~45K (06/91) #2430 1992 Dark Teal LS-L ~184K (05/91) #0739 1992 Claret LS-L ~196K (05/91) #0831 1992 Pearl LS-L ~103K (06/91) #1680 1992 Pearl LS-L ~151K (06/91) #2229 1992 Dark Teal LS ~150K (07/91) #3098 (parts car) 1992 White LS-L ~139K (08/92) #6913 1993 25th AE ~98K (02/93) #164 1993 25th AE ~58K (02/93) #176 1993 25th AE ~107K (02/93) #215 1993 25th AE ~162K (02/93) #223 1994 Laguna Blue Pearl LSi ~124K (1/94) #2408 1994 Laguna Blue Pearl LSi ~144K (10/93) #1484 1994 Laguna Blue Pearl LSi ~68K (10/93) #1525 1994 Barcelona Red LSi ~46K (02/94) #2624 1994 Pearl LSi ~41K (12/93) #1961 1995 Bordeaux Pearl LSi ~70K (02/95) #855 1996 Polo Green LSi ~95K (03/96) #872 1997 Bordeaux Pearl LSi ~55K (08/96) #097 2003 Brilliant Red LS1 Convertible ~29K (04/03) #8951 1999 Magnetic Red LS1 Coupe ~33K (04/99) #6420 My Email | Old Locker | New Locker | Picture of 15 of the 19 |
Some have had the PS hose leak at the back of the engine, Px side. The front seal will leak if run it hard. Best wishes for finding the leak and the smoke.
chances are
its one of the PS lines, Pass side back by the firewall
Ones pretty easy to replace, and about $15 the other one is about $150 and takes more time to install Either way Id almost bet thats your problem.
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
For your sake, I hope its not a 94L with the following VIN: JF1CX3350RK103623.
It all depends on what is leaking and how it all smell. I have my fair share of every type of fluids buring on a SVX before and most likely the easiest fix is your ATF burning. Check your PS hoses and see where it is leaking. If it is not your PS, check your tranny fluid and see if it is burnt. If it is burnt and is brown in colour, start saving money for a new tranny. If it is not ATF fluid burning but oil burning, you have 2 types of oil that can burn. Diff and engine oil. Gear oil smells different from engine oil. But you only get a ton of smoke from one of two things: PS leaking or Engine leaking due to some seal. If it is the engine leaking, you have to see where it is leaking. Also, when you check your fluids, are any of them lower than what they are supposed to be?
Lwin M. Maung (Member # 147) Current SVX: NONE Previous SVXes: 1994 LE Barcelona Red 107k 1992 LS-L Pearl White 143k 1994 LSi Bordeaux Pearl 220k 1992 LS-L Ebony Pearl 184k 1992 LS-L Liquid Silver 145k 1992 LS-L Liquid Silver 102k 1992 LS-L Ebony Pearl 123k Other current cars:2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
