car has issues when cold
When I first start driving my car in the morning and its cold the car wont accelerate if you give it more than a 1/4 throttle it feels like it wants to stall if you let off it accelerates fine.
any ideas? Thanks |
Re: car has issues when cold
http://members.tripod.com/adm/popup/...d561851ad8a2a8
The throttle body is spotless
mine is doing this weird idling thing.
the rpm tach will just move between 1000rpm and 2000rpm and every now and then it will just die. but it cranks right up? in ideas?
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!! "Too much fun to drive!" |
Leo - Thats what mine was doing for a while. My mechanic thinks it was the coolant temp sensor (thats the error code the ecu gave him), he replaced it and I haven't had starting issues since then. Maybe something to look into ... I think it was error code 21.. check out:
http://www.subaru-svx.net/archive/ar...?message=53511 |
