Tire Recommendations
Would appreciate suggestions for new rubber. More interested in a quite ride than performance. Any words of wisdom on allignment would also be appreciated.
After a year and a half, my little red SVX just turned over to 32,000 miles. I live in North Palm Beach, FL. |
Re: Tire Recommendations
Hi,
One thing to keep in mind if you have an all wheel drive car, the tires must be very close in size.If you have mismatched size tires, you risk damaging drivetrain component$. Which means that a full road hazard warrenty won't be much help. If you have a blowout, punctured sidewall, or otherwise trash a tire once they are 50% worn, 1.You will have to find a tire that is the same size/brand with same wear 2. Buy new tire and have it shaved 3. Buy 4 new tires(what most do). That said, I have had Toyo Proxes FX4, Falken Zeix 512(all season V rated) and FK452(summer only) Continental, and Kumho Ecsta MX (summer only), Nitto (snows) and Hankook Icebear (V rated snows) tires on our SVXs. The quietest were the Contis (H-rated).
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
Match the edge profile of the OEM Proxes ie rounded rather than square. The suspension likes the tires move a bit more than the square edge allows which cause the square edges to wear prematurely.
32,000 miles! Maybe you should put it on blocks & store it then get another to drive. Last edited by SVX_MY_BABY; 08-18-2008 at 06:43 AM. |
One naging problem both he & I have had for a number of years, - - we thought it was some sort of "draw" on the battery. A series of higher & higher capacity batteries until I just recently was told that his mechanic had replaced a failed alternator with one 85 amps (instead of the 95, factory one). Found this when the 85 amp one failed me. I am hoping that this will solve the problem. (I have been somewhat suspecious of the security system, [ which neither of her 2 owners know how to use ].) 92 30K mile SVX |
I have a set of Michelin Pilot Exalto A/S in the stock size 225/50R16. It's considered a high performance all season tire and I use them for my "winter" tires. The ride is amazing, and they also handle very well.
A VERY good tire, if you ask me. I work at a tire shop and I recommend these as often as I can. Here's a link to them on tirerack. THey are currently priced at $130 each, which is a pretty good size considering the performance, ride, and the life you'll get out of them. http://www.tirerack.com/tires/tires....t+Exalto+A%2FS
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! Last edited by Nevin; 08-17-2008 at 10:07 PM. |
Your tires are like mine, dead long before the tread. Falken Azenis might be good for you or Bridgestone RE-01a (stock on the STI). Good solid value tires that will net you about 10k-12k on them.
cooper xeon are the choice tires for mine as they work good in ALL( including snow) weather, ride quiet and have good tread wear. my opinion plus they are not as costly as most
William |
I would never shave tires, and would only replace them 4 at a time. Never replace only 2 at a time. Good luck on your search for tires.
Are you staying with the stock wheels?
1997 Boudreaux LSi 1994 SVX LSi(SOLD) Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3 |
92 30K mile SVX |
